235/45/17 - FirebirdV6.com/CamaroV6.com Message Board
  • 235/45/17
    If I use these tires will I need to lower my car too? since these are low profile ones
    No, with a 45 sidewall the larger diameter of the rim should make up for the slightly smaller sidewall. A 40 side wall you might consider lowering it.
    \'99 SSM Camaro V6 M5<br />(mod list on cardomain site; too long to list here)<br /> <a href=\"http://www.cardomain.com/id/v6cam99\" target=\"_blank\">http://www.cardomain.com/id/v6cam99</a>
      If you're on 17x8 rims, you might get a better fit compared to stock with 245/45-17's.
      That's what I'm using here, some nice choices are available.
      2001 Pewter Firebird Y87, M5
      Go Sabres!
        i'm riding on 235/40/17's and i would love to lower my car but i already bottom out on everything even speed bumps. check out my pics to see the wheel gap. you should be fine.
        WAWA-A-HOLIC
          yeah yours looks nice so it should be no problem ;)
