tire sizes and how they effect me? - FirebirdV6.com/CamaroV6.com Message Board
  • tire sizes and how they effect me?
    Im going to purchase tires today for my firebird. The front tires are worn out badly. They are 225/60/16. My rear tires are fine, they are 235/55/16.
    If I keep the same size on front or goto 235/60/16 will there be any negative effects as opposed to going to the same size as the rear?
    Thank You.
    \'93 Firebird 3.4<br />\'90 CRX-Si W/ZC<br />\'95 Jeep Cherokee
    Thank You.
    You mean 235-50-16's all around...right? A 235-60 will have a slightly higher sidewall. Prbably no real big effects, but if you want *and can afford* all 4 tires, go with 245-50-16's (or even better, 255-50-16's) all around. Better traction, and looks better than the cheezy 235's.
      There was a website that showed the difference in tires and how they affect the speedo in a % I can't seem to find it though.
      95 3.4L <br /> <a href=\"http://www.myspace.com/1277388\" target=\"_blank\">http://www.myspace.com/1277388</a> <br /> <a href=\"http://www.cardomain.com/profile/altspacen\" target=\"_blank\">http://www.cardomain.com/profile/altspacen</a> <br /><a href=\"http://groups.myspace.com/camarov6\" target=\"_blank\">http://groups.myspace.com/camarov6</a>
        HERE
        2000 Monterey Maroon Chevrolet Camaro<br />3.8L V-6/4spd Auto
          please run one of the following appropriate sizes.
          P225/55R16
          P235/55R16
          P245/50R16
          P255/50R16
          2002 5-spd NBM Camaro
          Details: www.1lev6.com
            You didn't mention 215/60-16 which is one appropriate choice, since it's a stock size. I know most here simply don't like to run them, but I do in winter. And if you value ride and rain handling above all else, they're the hot setup.
            Mykal - the best idea is to have all 4 the same size. Among other things, it lets you rotate them properly.
            2000 Firebird convert, chameleon/tan, M5, Y87, TCS, BMR tower brace and panhard, KBDD sfcs, 245/50-16 GSCs
              Well with an 8" wide rim is a 215 safe? I prefer to run a 225 at the minimum on an 8" wheel (which is what is DOT recommended accoriding to Tirerack.
                Interesting point. The funny thing is that GM shipped out 90+% of their V6 fbodies with 215s. But almost all the 215s I looked at specced a max rim of 7.5.
                The exception was one model of Eagle GAs, which had a max rim of 8.5 and which I think is what GM used.
                So maybe 215s aren't a good idea unless you use one of the rare ones specced for the 8 inch rims.
                  why not go with the 235/45/16 low profile :D
                    Basically I was trying to save some cash. I planned on buying 4 new tires next month. My front tires didnt make it though. I went to a used tire place and got 225/55/16 for up front and kept the 235/55/16 in the back for now.
                    I didnt realize I could run 245s or 255s on the stocker rims.
                    Thanks for all the help.
