well it was nice out, and i check under my car nothing seem bent or broke but i dont really know what im sopossed to be looking for.my car is sagging,bad. :( between the tire and the fender theres only like 1 inch but on the other side theres alot more about 3 or so. the frame needs to be pulled im sure.but should i get new shocks? the car only has 41k on it so id rather not get shocks just yet if i dont have to.any suggestions will be apreciated. thanks
checked under car,still sagging HELP!
Might actually be a spring fatigued. You may wanna try checking them first before you just start throwin money at the car tryin to fix it. Just take the rear springs out and set them side by side, see if there's a difference. It prolly shouldn't take more than an hour to take them out, check em, and put em back in. And that's on your first try.~Chris<br />1999 Hugger Orange Camaro<br /> <a href=\"http://www.cardomain.com/ride/273836\" target=\"_blank\">http://www.cardomain.com/ride/273836</a> <br /><br />†…faith…hope
my car is sagging like hoe to !!!!!!!!!!!!!!! grr pass side is worse !!!!!!!!!!!!www.turbov6camaro.com
1997 3800 Series II Camaro
Originally posted by Crashtest:
Ummmm, go to Midas, or Sears, they will throw it up on the rack for free & let you know whats up.www.turbov6camaro.com
will they realy do it for free?thats really cool.thanks guys for the info. im hopeing its something easy where i can do it my self..but sadly i couldnt even get my lug nuts off yesterday when i tryed :( [img]redface.gif[/img] grrr im too young, my dad had to do it.
EDIT: viper how exactly is yours sagging? mines pretty much just the front but the back is sagging because the front is so bad.i only have like an inch between the fender and tire. and if you do go somewhere will you tell me what they think it is? thanks1998 bright red camaro ,M5 ,Y87 ,stock<br /><br />Originally posted by Rune:<br />If it smells like a turd and looks like a turd, chances are its probably not a candy bar.
Originally posted by viper04af:
</font><blockquote>quote:</font><hr />Originally posted by Crashtest:
Ummmm, go to Midas, or Sears, they will throw it up on the rack for free & let you know whats up.95 Firebird<br /> <a href=\"http://www.cardomain.com/memberpage/673250\" target=\"_blank\">http://www.cardomain.com/memberpage/673250</a> <br /> <a href=\"http://photobucket.com/albums/y217/andrewbrandon19/\" target=\"_blank\">http://photobucket.com/albums/y217/andrewbrandon19/</a> <br /><br />me on a good day------> <a href=\"http://communicatio.webblogg.se/images/wet_cat_113159625.jpg\" target=\"_blank\">linky</a>
loser:
my car is also a 98 and it had sagging springs from 35k miles when I bought it in 2001. I just broke down and put 1LE springs all the way around it. 2 ways I knew it was sagging, 1st the obvious parked next to another v6 firebird it was visibly lower. 2nd it could not be completely aligned, the driver side front tire had negative camber (the tire was leaned in at the top) even with the setting on the A-arm all the way in. Anyway with 1LE springs I can practically jump curbs now [img]tongue.gif[/img]-Brad
2000 V-Star Custom 1100
:rock:
black98v6 was your hole car sagging or just one side? my car was wrecked so im gusseing thats what caused it,mines just the front passenger side, the back sags too but i think that becuase the front is so bad.but all you did was get springs? i was thinking shocks,or sway bars or something.1998 bright red camaro ,M5 ,Y87 ,stock<br /><br />Originally posted by Rune:<br />If it smells like a turd and looks like a turd, chances are its probably not a candy bar.
Originally posted by andrew.brandon:
</font><blockquote>quote:</font><hr />Originally posted by viper04af:
they was 6n the 35st they are g65ng bad n6w s6 5ts d5fferent 363
- Justin<a href=\"http://www.njfboa.org\" target=\"_blank\">New Jersey F-Body Owners Association</a><br />1987 Camaro LT - 400sbc, Aluminum L98\'s w/valve job, Comp XE 274, Q-Junk 750, 3.23 posi, 4.10\'s soon.<br /><br /><a href=\"http://www.njfboa.org/forums/viewforum.php?f=11\" target=\"_blank\">East Coast F-Body Nationals - August 14, 2005</a>
overall it did have a bit of a lean to it also, but alas this is the problem with weak unibody cars espicially with the top cut off.
if your car was wrecked you might want to get it to a good body shop that can check the frame, it may be tweaked-Brad
:rock:
yea i know the frame needs to be pulled, but i dont think thats gonna completely fix the sagging problem.it just snowed yesterday maybe if my driveway drys up a bit ill go take a look again, but man those lug nuts are a pain.i hate being 14 :( . and btw my car doesnt have t-tops sadly.
thanks alot brad i appreciate it1998 bright red camaro ,M5 ,Y87 ,stock<br /><br />Originally posted by Rune:<br />If it smells like a turd and looks like a turd, chances are its probably not a candy bar.
i would but i dont have money.im only 14 so i dont really have a job.i got a paper route to pay for the car.it needs 2 fenders front and back bumpers and a windsheild, plus the frame and what ever is wrong with the shocks/struts/who knows.id love to have t-tops though.i plan on doing most of the work my self, like putting everything on/taking everthing off.thanks for the replys everyone.1998 bright red camaro ,M5 ,Y87 ,stock<br /><br />Originally posted by Rune:<br />If it smells like a turd and looks like a turd, chances are its probably not a candy bar.
