98+ Spring Question - FirebirdV6.com/CamaroV6.com Message Board
98+ Spring Question
  • 98+ Spring Question
    Does anyone know the actual specs for 98+ v6 and v8 front springs? I have heard that the rears are the same, but some people say the fronts are the same, some say they are different.
    I've lifted an LS1 and an L36, and I don't think there is much difference in weight. The LS1 is all-aluminum, and that makes a big difference. The only thing that I think would make a difference is where the engine sits in the car (since the LS1 overhangs the centerline of the front tires, and the front of the L36 is practically on the centerline.
    Any thoughts?
    - Justin
    <a href=\"http://www.njfboa.org\" target=\"_blank\">New Jersey F-Body Owners Association</a><br />1987 Camaro LT - 400sbc, Aluminum L98\'s w/valve job, Comp XE 274, Q-Junk 750, 3.23 posi, 4.10\'s soon.<br /><br /><a href=\"http://www.njfboa.org/forums/viewforum.php?f=11\" target=\"_blank\">East Coast F-Body Nationals - August 14, 2005</a>
    http://tech.firebirdv6.com/suspension.html
    2001 Pewter Firebird Y87, M5
    Go Sabres!
      The fronts vary some, see my website (suspension tech) for spring rates.
      2002 5-spd NBM Camaro
      Details: www.1lev6.com
        i'm actually going to do the v8 springs swap on my v6 in a couple of days from now, so if i find any differences, i'll tell you.
        99 Camaro RS - 3.8L V6<br /><br />Modifications<br />Exhaust: Magnaflow OBD-II High-flow Catalytic converter / Magnaflow catback exhaust<br />Intake: Shaved Airlid / 3\" PVC tub<br />Suspension: V8 springs / DeCarbon shocks / 32mm 1LE swaybar / 19mm rear swaybar
          doing the swap along with a 1LE front swaybar Wednesday, so if you're interested, I can tell you how the springs / 32mm swaybar is.
            Description: COIL SPRING
            Part #: 22077421
            Categories:
            Collision &gt; STEERING/SUSPENSION &gt; REAR SUSP
            Mechanical &gt; GROUP 9 - REAR SUSPENSION &gt; REAR SUSPENSION SYSTEM
            Add to Cart
            Make Model Year(s) Application
            Chevrolet Camaro
            1997-2002
            All applications
            Pontiac Firebird
            1993-2002
            Spring, Coil L
            1993-2002
            Spring, Coil R
            www.turbov6camaro.com
            1997 3800 Series II Camaro
              Viper, what site was that information from?
              - Justin
                - Justin
                gm parts direct
                it lists that 1997 and up had the stiffer springs
                so the data base for CV6 is wrong or GMPD is wrong
                  "so the data base for CV6 is wrong or GMPD is wrong"
                  I'm betting 97 is a misprint. 98 was the year of many changes.
                    Also, you listed rear spring rates and I was asking about fronts.
                    - Justin
                      97 also had alot of changes too. new tail lights, interior, and im sure some other unseen things.
                        ok, I did the v6 to v8 spring replacement and here are my thought. take into fact that my car has been sitting on the same springs for about 104,000 miles, so the springs that i replaced might have sagged a bit. From replacing the front, I noticed about a half inch at the most lift when switching to the v8 shocks and the rear also lifted about half a inch. since both springs off a v8 and v6 are the same, it just goes to show that the springs were sagging. I can't really tell about stiffness because I replaced my shocks and springs at the same time, so I can't give you a good / accurate feedback for stiffness.
