Wheel torque specs. - FirebirdV6.com/CamaroV6.com Message Board
Wheel torque specs.
  • Wheel torque specs.
    Any one know what the lug nuts should be torqued to on a 1997 firebird
    thanks
    [ March 22, 2005, 03:05 PM: Message edited by: 97SILVERBIRD ]
    97SILVERBID<br />Born to cruise
    100 ftlbs
    96 3.8 red camaro. <br />headers,cam,valve springs,retainers,auburn lsd,3.73 gears,SLP cold air,accel coils,24lb injectors,8mm plug wires,air temp module,LT1 diveshaft,removed a/c,edelbrock torque arm,spohn LCA\'s and PHR
      Thanks for the fast reply Timmy
        Aren't they all supposed to be 100ftlbs..
        95 3.4L <br /> <a href=\"http://www.myspace.com/1277388\" target=\"_blank\">http://www.myspace.com/1277388</a> <br /> <a href=\"http://www.cardomain.com/profile/altspacen\" target=\"_blank\">http://www.cardomain.com/profile/altspacen</a> <br /><a href=\"http://groups.myspace.com/camarov6\" target=\"_blank\">http://groups.myspace.com/camarov6</a>
          no.
          98-02 is only 99ftlbs
          1994 white Firebird M5<br />Flowmasters, CAI, 3.73s, LSD, coated pacesetters, eibach pro-kit, bilsteins, hurst shifter, JVC stereo, 18\" C5 vette wheels, Kuhmo Ecsta ASX rubber<br /><br /> <a href=\"http://www.cardomain.com/memberpage/744299\" target=\"_blank\">http://www.cardomain.com/memberpage/744299</a> <br /><br />Coming Soon: Turbo!
            THATS why I've stripped the threads off the 98-02 lugnuts that I bought.. damn
              yeah u gotta be carefull with over-torquing those nuts [img]graemlins/rofl.gif[/img]
                Steel rims only require around 60-65 ft lbs, aluminum 100 ft lbs
                69 Camaro 350 4spd, Full Hotchkis susp, Baer brakes, moser 12 bolt, Flowmaster<br /><br />96 RS Hotchkis STB, subframe connectors, Hotchkis LCA and adj Panhard rod, SS camaro sway bars, Bilstein shocks, powerslot rotors, Borla exhaust, rksport headers, k@nFIPK
                  All stock wheels are 100 ft lbs. ;)
                  Matt
                  1998 Mystic Teal Camaro M5
                    I have the chrome stock wheels so it looks like 100 ft lbs.A few differant answers here so I hope I picked the right one
                    Thanks again for all your input
                      Stick with 100 ft-lbs and you shouldn't have anything to worry about.
                        To clarify:
                        All 3rd gen and up wheels are 100 ft-lbs
                        1st and 2nd gens with alloy wheels are 100 ft-lbs
                        1st and 2nd gens with steel wheels are 80 ft-lbs
                        Basically you can to use the stud to figure it out, 1/2" and 12mm studs are 100, 7/16" studs are 80.
                        1997 Dodge Viper GTS
