What do they recommend? is 255 as wide as I can go? or can a force a 275 on there? I'm having problems because I found a great deal on Eagle Alloy 077 for only $375 new (set of 4)! But I can't get a nice fat tire on there which is a huge downer and maybe not worth it? [img]graemlins/thumbsdown.gif[/img]
The wider you go, the more uneven the wear is. 255 is a good fit. 275s would probably have VERY uneven wear. If traction is the purpose then you won't be helping yourself.
\"Since I started working, every single day has been worse than the day before, so that every day you see me is the worst day of my life\"
Depends on the diameter of the wheel. You can run a wider tire on a 16 x 8 than you can on an 18 x 8.
Check tirerack.com for recommended wheel widths for different size tires, to get an idea. Pick a tire, like a goodyear for example, then choose "specs". It will show you a table of all the tire sizes, tread widths, section widths, and recommended wheel width for that tire model.
