I have a 98 firebird and have stock rims i think are 16x8 so do es anyone know if these rims will work without rubbing the fenders http://www.mickeythompsontires.com/press_11_17_03.html
Will these tire work
I'm pretty sure they won't rub. Especially with the 255/50/16s, they won't rub for sure. I think the stock tire size was 215/60/16 and some got the 235/55/16 tires and there is stil a lot of room to play with. If you decide to get those tires, you should definately get an alignment after.99 Camaro RS - 3.8L V6<br /><br />Modifications<br />Exhaust: Magnaflow OBD-II High-flow Catalytic converter / Magnaflow catback exhaust<br />Intake: Shaved Airlid / 3\" PVC tub<br />Suspension: V8 springs / DeCarbon shocks / 32mm 1LE swaybar / 19mm rear swaybar
- Justin<a href=\"http://www.njfboa.org\" target=\"_blank\">New Jersey F-Body Owners Association</a><br />1987 Camaro LT - 400sbc, Aluminum L98\'s w/valve job, Comp XE 274, Q-Junk 750, 3.23 posi, 4.10\'s soon.<br /><br /><a href=\"http://www.njfboa.org/forums/viewforum.php?f=11\" target=\"_blank\">East Coast F-Body Nationals - August 14, 2005</a>
by ssms5411Haven’t done anything on the Camaro, but put LEDs on my truck headlights . And my oil pressure sensor went out on the truck so going to fix that this...5 days ago
