Will these tire work - FirebirdV6.com/CamaroV6.com Message Board
  • Will these tire work
    I have a 98 firebird and have stock rims i think are 16x8 so do es anyone know if these rims will work without rubbing the fenders http://www.mickeythompsontires.com/press_11_17_03.html
    <a href=\"http://www.cardomain.com/profile/blackfbird_98\" target=\"_blank\">http://www.cardomain.com/profile/blackfbird_98</a>
    oh i am wanting the 255/50/16
      I'm pretty sure they won't rub. Especially with the 255/50/16s, they won't rub for sure. I think the stock tire size was 215/60/16 and some got the 235/55/16 tires and there is stil a lot of room to play with. If you decide to get those tires, you should definately get an alignment after.
      99 Camaro RS - 3.8L V6<br /><br />Modifications<br />Exhaust: Magnaflow OBD-II High-flow Catalytic converter / Magnaflow catback exhaust<br />Intake: Shaved Airlid / 3\" PVC tub<br />Suspension: V8 springs / DeCarbon shocks / 32mm 1LE swaybar / 19mm rear swaybar
        They'll work.
          definately will work... no problem.
          2004 CE Corvette 10.86@132mph
          2011 Cadillac CTS-V
          2006 Mitsubishi Eclipse GS
            Why would you bother with a front end alignment after mounting drag radials? They won't change the alignment at all.
            - Justin
