You could search and find out a ton about this probably.
But It makes it look a lot better, mine roughly dropped an inch on all 4 wheels.
Ride is a rougher, i dont think too much worse though. If you own a camaro in the first place, you shouldn't worry about the ride too much. It does not make it that much worse.
Handles a lot nicer than stock springs, overall it is definately worth it.
I got the prokit, but I went with the 93-97 on my 99 because it is a lower springrate. It dropped my car a full 2 inches all the way around. But my car was very 4x4ish before.
It doesn't ride rougher, but it is a lot more sensitive, if you are still on stock width 16s and stock shocks, you might not like it.
Get some GOOD shocks to go with it. Your gonna needs some stiffer shocks to help control those higher spring rate springs.
I can't vouch for the springs along, but with prokit springs, KYB adj. AGX shocks, and a 32mm Front stabalizer bar with new enlinks and poly bushings. The car can handle a hell of a lot more speed in corners.
Ok... basically, I have very limited funds... so I wasn't going to be able to do shocks/springs/the whole nine yards. I was just going to do the springs.
Not a good idea?
<b><a href=\"http://i6.photobucket.com/albums/y239/jdub4105/firebird2.jpg\" target=\"_blank\">1999 Firebird 3800 II</a></b><br />--Flowmaster 80<br /><b><a href=\"http://i6.photobucket.com/albums/y239/jdub4105/full_21019_p311165.jpg\" target=\"_blank\">1996 Mustang GT *SOLD*</a></b><br />--Pulleys, H pipe, Flowmaster 40\'s, Ford Racing clutch<br /><b><a href=\"http://i6.photobucket.com/albums/y239/jdub4105/camaroheader.jpg\" target=\"_blank\">1998 Camaro 3800 II *SOLD*</a></b><br />--Cutout, SLP CAI, Whisper Air Lid, K&N Filter, SS rims
You can get SLP take-off shocks from when the upgrade Z28's to SS's. They put new shocks and suspension parts on the SS's so they take off the stock Z's shocks and sell them. They usually have at most around 1000 miles on them probably. The Z28 shocks are stiffer rebound so they work well with the lowering springs.
BTW they only cost $50 (for all four of them).
A lot of people have done this, it also allows your old shock to not suck. Because with stock springs, you are riding at a certain height all the time, so your shock is used to that motion, when lowered you move that point in the shock after a bunch of miles, so it doesn't ride worth ****. That is why you should really get new shocks. At least spend an extra $50 and get the Z28 take-off shocks.
i wanna get the pro-kit too. If i get those with the z take off shocks, will my suspension still be alot stiffer/better handling thru corners and stuff?
yes, the Z28 shocks have a stiffer rebound than our stock v6 shocks from what I was told (makes sense, because the spring is stiffer in those cars). It will leave you with a lot better handling car. This is the setup I have and I have taken my car to the track a few times. Handles nicely, now I am adding swaybars, etc. You will enjoy it if you go this route, and when or if you feel like switching to better shocks, like Bilstein or KYB, you can get them later and install them, and you only lost $50.
ebay... found these and the guys has a bunch more sets as well.. $80 for the set http://cgi.ebay.com/ebaymotors/ws/eB...category=10076
im sure you can find other stuff to if you looked around some...
gotta say i like my prokits as well. i went for bilsein hd's though and installed everything at the same time. dropped my car bout an inch all around. handles much tighter now... good luck
Phill
3 days ago
