Ok I got my rotor cut and new pads on the front. What do you guys think is the best way to break in new brakes. I know not to go slamming on them. However, should I try to bed them or just take it easy for a while?
1998 Navy Blue A4 Camaro (Sold)<br />MODS: Performance<br />Whisper airlid,K&N Filter, TSP Rumbler & Carsond cat.<br />Apperance:Xenon Airdam and clearcorners. <a href=\"http://www.cardomain.com/id/wilkcamaro98\" target=\"_blank\">http://www.cardomain.com/id/wilkcamaro98</a><br />2002 Dodge Ram Sport Silver 4.7 v8 stock.Tags: None
The manufacturer usually "suggests" methods for breaking them in. I'd look into that.<a href=\"http://www.cardomain.com/id/briansr\" target=\"_blank\">97 White Pontiac Firebird 3.8 A4</a><br />Mods- 2.75\" exhaust, Dynomax muffler, magnaflow cat, SLP CAI, Hypertech 160* thermo, Fan switch<br />Suspension-Kumho Ecsta 712\'s, 32mm/19mm sway bars<br /><br />Our Lady of Blessed Acceleration, don\'t fail us now. <br />-Elwood Blues
As white shark posted, the suggested manufacturer procedure should be followed.
Here is a generic way to "break in" or "bed" your rotors and pads:
Before driving off while car is in park pump you brakes to make sure you have pedal.
Slowly accelerate to around 30 mph and then apply the brakes and decelerate to about 5 mph.
Slowly accelerate to around 40 mph and then apply the brakes and decelerate again to about 5 mph.
Again slowly accelerate to about 50 and brake to about 5 mph.
Finally do this once more to about 60 and again brake to about 5 mph.
This should get them properly heat cycled to give you long life.
If at all you can help it,do not come to a complete stop and then keep the brakes depressed while bedding.
Also the accelerating slowly back up to speed between stops is important so that the brakes can cool down a bit between braking.
cool thanks guys.1998 Navy Blue A4 Camaro (Sold)<br />MODS: Performance<br />Whisper airlid,K&N Filter, TSP Rumbler & Carsond cat.<br />Apperance:Xenon Airdam and clearcorners. <a href=\"http://www.cardomain.com/id/wilkcamaro98\" target=\"_blank\">http://www.cardomain.com/id/wilkcamaro98</a><br />2002 Dodge Ram Sport Silver 4.7 v8 stock.
yeah, the SAE recommended procedure is 30 moderate stops from 30 mph to 0 with approx 30 seconds in between to cool.Phill<br /><br />95 camaro... need money for turbo project... <br />94 S10 Blazer - winter beater - infinity system to be installed soon<br /><br />\"The man who says it cant be done should not interrupt the man doing it...\"
Originally posted by camaroman1181:
yeah, the SAE recommended procedure is 30 moderate stops from 30 mph to 0 with approx 30 seconds in between to cool.2000 Monterey Maroon Chevrolet Camaro<br />3.8L V-6/4spd Auto
yup.. its referred to as the 30/30/30 method.. if i can find teh link i'll post it...Phill<br /><br />95 camaro... need money for turbo project... <br />94 S10 Blazer - winter beater - infinity system to be installed soon<br /><br />\"The man who says it cant be done should not interrupt the man doing it...\"
i overheated mine lol
i used the Baer brreak in method and my nrakes were smokin when i was finished1994 white Firebird M5<br />Flowmasters, CAI, 3.73s, LSD, coated pacesetters, eibach pro-kit, bilsteins, hurst shifter, JVC stereo, 18\" C5 vette wheels, Kuhmo Ecsta ASX rubber<br /><br /> <a href=\"http://www.cardomain.com/memberpage/744299\" target=\"_blank\">http://www.cardomain.com/memberpage/744299</a> <br /><br />Coming Soon: Turbo!
Re: best way to break in new brakes
sorry to bring this from the dead, but I just did my breaks and rotors and wanted to see what you guys thought compared to my results.
The purspose of this excercise is to get the rotors up to their heat cycle to maximise life and to do this the rotors must undergo a pad material to rotor transfer. The rotors smoking or smelling is completely normal and from what i've found going 60-10 and back up to 60 five to six times is good enough for our cars; unless, you have high performance rotors and pads you should wait until the brakes are completely cooled and then perform this for a second cycle.
Be careful the first time you go out with your new equiptment because they might not function properly until after a couple pushes of the pedal.<a href=\"http://albums.photo.epson.com/j/AlbumIndex?u=4187730&a=31095602&f=\" target=\"_blank\"> 2000 Black Firebird Y87 </a> <br />K&N filter, Whisper Cold Air Intake, Cutout Exhaust;<br />3.42 Gears, LSD;<br />160* Powerstat, Removed Silencers, MAF screen removed;<br />Zex hyperformance Spark Plugs, MSD Superconductor Wires, Manual Fan<br />Switch<br />15.08@90.86 2.149 60ft
by ssms5411About a week ago noticed my brake lights not working also Hazards not working. Installed new brake switch and still not working, checked fuses and what...3 days ago
