problem with strut bar !! - FirebirdV6.com/CamaroV6.com Message Board
  • problem with strut bar !!
    my front strut bar (BMR) doesnt fit on, its like the baris just off by a lil bit but its too much to force it on. any ideas? its like the body is a lil too small/scrunched
    Dave:
    00 Supercharged Camaro - RIP
    97 Turbo Camaro - Sold
    Sounds like you have a V8 bar, or your V6 bar was made funny. If its the V6 bar, it's supposed to lean back. Checkout the engine photos on my website to see how it fits.
    2002 5-spd NBM Camaro
    Details: www.1lev6.com
      Yeah, the V8 one is straight, but our V6 one "leans back" to clear the alternator. Unless you mean that the ends of the strut bar don't quite fit onto the bolts on the tower. Then your V6 bar was just made funny I suppose. Some of the new ones are a bit tight at first... you may have to wiggle it or maybe even widen the hole a little bit on the ends.
      ::edit::
      I added some pics of it on my car so you can see what I'm talking about:
      Pic 1
      Pic 2
      [ April 13, 2005, 09:30 PM: Message edited by: ArticRider ]
      Yes, I know \"Artic\" should be spelled \"Arctic\". Can any of the mods change this?
        its the v6 bar im positive, it just barely doesnt fit. even with the wiggling and pushing. i even tried puttin my car on jacks, helped a lil, but not enough..
        any other ideas?
        Dave:
          If it's the bolts that kinda make it tight on each side, you could try widening the holes on the ends of the bar a little bit. I got my STB used, so the previous owner must've already done the work already if it didn't fit, cause mine went in with a little nudge. I dunno any other suggestions. Good luck with it!
            your not putting it in backwards are you? just had to make sure. ;)
            My BMR went in nice and easy. clearance wasn't a problem and just screwed the bolts in.
            http://www.bowtiev6.com/
              no, im putting it on right, and there isnt enough room to drill the hole out to make it bigger or id run off the side of the strut bar, so i dont know what else i can do to make it fit.
              Dave:
                What I have to do on mine is get one side on, and wiggle the other one on with a friend and a rubber mallet.
                2002 Silver Metallic A4 Firebird - All Options
                Hotchkis STB, Custom Madrel Bent 3" Exhaust, Pacesetter Headers, Whisper Lid, FT Ram Air, K&N Air Filter, D2S HID, Baer Rotors, !EGR, !MAF, 10% tint, Parrot CK3300
                Your Mom or My Dad?
                  tried it! :( :(
                  Dave:
                    www.prototypestudios.com/DMW/misc/s1.JPG
                    and
                    www.prototypestudios.com/DMW/misc/s2.JPG
                    i took those today, it wont budge!!
                    Dave:
                      Hey dmw, i sold you the strut bar and i see ur still havin trouble with it, i bought the bar brand new from thunder racing it is a v6 bar, it fit with no problems on my v6 97 firebird, but maybe while it was on my car it somehow bent or warped the bar just enough to give you the problems ur havin. If anything i will refund ur money, if you can't find a way to get it installed.
                        ok thanks man. ill let you know. im going to try it on my friends camaro today and see if its just my car, or his car as well. thanks for your understanding.
                        Dave:
                          O.K., after all this, who sells a good bar that will fit? I want to get one. 1994 v6. Thank you.
                            I have installed many of these STB, I have never seen one not fit correctly, especially after coming off of another car. Unless the car that the STB is being installed onto has been in a wreck.
                            Ryan
                            1998 Ws6 Ta M6 #370 Bright Red<br />Custom \"NX\" style switch panels $35<br />Plug in fan switches $50 <br />SLP lid, Pro 5.0, Corsa, Custom Fan switch<br />....vortech waiting to be installed.
                              try putting both sides on at the same time, not one side on then the other.
                              Then tighten the bolts down on it.
