SLP Bilsteins compared to Bilstein HD's - FirebirdV6.com/CamaroV6.com Message Board
  • SLP Bilsteins compared to Bilstein HD's
    This is some good info for the tech data base since its a question that i have seen come up so many times when people are wanting to lower their cars. I found this on LS1tech after massive searching [img]smile.gif[/img]
    Bilstein B46-1913 front
    Compression: 159
    Rebound: 279
    Bilstein/SLP B46-2071 front
    Compression: 130
    Rebound: 397
    As you can see, the compression rate on the SLP Bilstein is only slightly softer than the Bilstein HD. What matters more to me, especially on a lowered car, is the rebound rate. This maintains a controlled, firm feeling when working on uneven surfaces and prevents the "bouncing" feeling with a lower, stiffer spring. If you're using a stiffer spring, I'd go with the SLP Bilsteins!
    2002 Maple Red Firebird V6<br />3.73 w/ LSD | Pro-5.0 Shifter | Fan Switch | Tach w/ Shiftlite | Boost and Fuel Pressure Gauge | Bilstein Shocks & 1LE Springs | 1LE 32mm Bar & Poly Bushings, Poly Tranny Mount and Torque Arm Bushing | BMR LCA\'s | Catco 3\" Cat w/ Edlebrock 5509 Muffler, (all 3\") | Corbeau A4 Seats (Pair) |<p><a href=\"http://forums.fakeleg.com/\" target=\"_blank\">http://forums.fakeleg.com</a><br /><a href=\"http://cv6.fakeleg.com/\" target=\"_blank\">http://cv6.fakeleg.com</a> - Part & Repair Manuals and write-ups.
