I just read in the tech database that some f-bodys came with koni double adjustable shocks stock...wtf?....is this a good upgrade and are these readily available in the aftermarket? what spring package came on these?
Koni Shocks
They arent worth the money you are going to spend on them. They adjust rebound and compression. The only reason i could see you getting these shocks would be if you were really dedicated to AutoCross racing, like SCCA. On your daily driver i wouldnt get anything but but Bilstein's, Koni (Yellow's, single adjustable), or some KYB AGX shocks.2002 Maple Red Firebird V6<br />3.73 w/ LSD | Pro-5.0 Shifter | Fan Switch | Tach w/ Shiftlite | Boost and Fuel Pressure Gauge | Bilstein Shocks & 1LE Springs | 1LE 32mm Bar & Poly Bushings, Poly Tranny Mount and Torque Arm Bushing | BMR LCA\'s | Catco 3\" Cat w/ Edlebrock 5509 Muffler, (all 3\") | Corbeau A4 Seats (Pair) |<p><a href=\"http://forums.fakeleg.com/\" target=\"_blank\">http://forums.fakeleg.com</a><br /><a href=\"http://cv6.fakeleg.com/\" target=\"_blank\">http://cv6.fakeleg.com</a> - Part & Repair Manuals and write-ups.
The Koni's are some of the best shocks you can buy given you can a) afford them, and b) adjust them properly for your springs.
I personally find the Bilstein shocks, or a well revalved set of Bilstein shocks, perfectly adaquest for stock or aftermarket performance springs respectively. Sadly from what I've heard about the KYB AGX shocks is that they're nothing but *ahem* poo and should not be used. The adjustability on a KYB only adjusts the FIRMNESS of the shock, not the actual rebound or compression, so you end up blowing shocks easily trying to make it compress less or rebound more.
The Koni's are great shocks they're just simply high in price. You really don't need to pay that much to get a similar spring/shock capability though, thats why most people find they can go with a good set of revalved Bilsteins and be perfectly satisfied [img]smile.gif[/img] .
The only thing adjustability offers you is a quick way to go from dragrace to autocross to roadrace to daily driver settings in a couple of minutes without swapping shocks. Again, for most people this is not a necessary thing to have, but I guess it is pretty novel [img]smile.gif[/img]2002 5-spd NBM Camaro
Details: www.1lev6.com
Wait ... the Double-Adjustable Konis found on the 1LEs are $450 for 4? I thought one koni (DA) could run nearly that to begin with ...
Though, remember, a HAL set is coilovers, and SA ... Konis are just shocks.
-Rob
[ September 01, 2002: Message edited by: Wicked 3800 V6 ]</p><b>97 Camaro 3.8L M5</b><br />Car for sale<a href=\"http://terpmotors.com\" target=\"_blank\">terpmotors.com</a> Terrapin Motorsports! UMCP
<blockquote>quote:</font><hr>Originally posted by Wicked 3800 V6:
-Rob
[ September 01, 2002: Message edited by: Wicked 3800 V6 ]<hr></blockquote>
It does... from GMparts direct a full set of Koni's would cost over $3,000 - not worth it.
You can buy Koni DA's for around $700-800 for all 4 from LG.2002 5-spd NBM Camaro
My mistake, i put the wrong part numbers in gmpartsdirect.com, but they're not 3000, they're 1400 for 4. But my original question still stands, what's the difference (if any) from the konis that came on the 1LE package as opposed to the aftermarket double adjustables.1993 Camaro 3.4L A4 many mods comin for 2004<br /><br />\"The last thing I wanted was to get in a fight in Jackson, Mississippi on a Saturday night\"
I believe the aftermarket version is stiffer on its softest setting... Keep in mind you need to know a lot about the shocks and springs you're using to properly adjust those shocks - its not an easy task.
15 ways to set them wrong, 1 way to set them right.2002 5-spd NBM Camaro
i have the double adjustables on my car in the front the were expensive i think like $442 or something thats why i only bought the front ones i had bilstein revalved before and they suck. the Koni's are absoulutly incredible but i do alot of autocrossing i wouldntsuggest putting them on a daily driver un less youve got the cash•)))2000 3.8L V6 FIREBIRD (Navy Blue) 5 speed <br />•Aluminum Alloy 3-piece custom built wheels - 17x10 (front)- 17x11.5 (rear) Tires:Front: 275/40-17 - Rear:315/35-17• Suspension Techniques 1 3/8 \" Solid front Sway Bar• H&R Springs • Koni revalved double adjustable shocks (front)• Bilstien Custom Revalved shocks (rear)• K&N •Magna Flow Dual Exaust• Stock wheels W/Hoosier Road Racing tires • Sound System•<br /><a href=\"http://www.cardomain.com/id/o0oskamo0o\" target=\"_blank\">•THE RIDE•</a>
What i'm really looking for is the best combo daily driver and performance shock. I can't go full out performance because the roads in mississippi are so horrible that i need some cushion. I'm more concerned about performance than price. Are konis the best?1993 Camaro 3.4L A4 many mods comin for 2004<br /><br />\"The last thing I wanted was to get in a fight in Jackson, Mississippi on a Saturday night\"
<blockquote>quote:</font><hr>Originally posted by O0oSKAMo0O:
i have the double adjustables on my car in the front the were expensive i think like $442 or something thats why i only bought the front ones i had bilstein revalved before and they suck. the Koni's are absoulutly incredible but i do alot of autocrossing i wouldntsuggest putting them on a daily driver un less youve got the cash<hr></blockquote>
Yes for a daily driver they're probably a hassle, and for that kind of money you can buy 4 pretty good shocks that aren't tunable but will still deliver good performance [img]smile.gif[/img]
For serious autocross though, Konis are probably the only way to go - you can only do so much with tire pressure :D2002 5-spd NBM Camaro
<blockquote>quote:</font><hr>Originally posted by MississippiMaro:
What i'm really looking for is the best combo daily driver and performance shock. I can't go full out performance because the roads in mississippi are so horrible that i need some cushion. I'm more concerned about performance than price. Are konis the best?<hr></blockquote>
If you're just looking for an all around good at everything but not best at anything shock - there are a few good choices. The Bilstein HD standby comes to mind - while it isn't the best shock on the planet it seems to do well and satisfy most people who don't race every sunday [img]smile.gif[/img] .
It just really depends on how deep your pocketbook is, what kind of springs you have, and what level of performance you desire out of new shocks to determine what shocks you should buy.
Koni's are generally considered to be very stiff shocks - they will not ride "cushy" at all, and are meant for track use. For some the ride is fine, for others its too stiff - go figure [img]smile.gif[/img] .2002 5-spd NBM Camaro
by 2.8 BirdI wish you guys the best for you and your family. Good health, happiness and prosperity. Merry Christmas and a happy new year....8 hours ago
by ssms5411Just ordered some Toyo 315/35/17 tires for my 17x11 rims. Hopefully I can get them on the beginning of next year. Will post pics.10 hours ago
by ssms5411Haven’t done anything on the Camaro, but put LEDs on my truck headlights . And my oil pressure sensor went out on the truck so going to fix that this...1 week ago
