Fuses are ok... 3rd brake light is on... why is it comming on? Comes on durring driving if i put it in nutrel and restart the engine it goes away for awhile.
ABS Light randonly comes on.. help!
if you put to big of tires on your car and it cant stop the car properly it disables abs for some reason it happend to me when i changed tires for a while and try to stop. I ended up bout 30 yards farther than i hoped =\91 Eagle Talon Awd Turbo 5 speed FOR SALE 6000$<br />Looking for a Fiero GT<br /><a href=\"http://www.swdsm.net\" target=\"_blank\">www.swdsm.net</a>
Check all the connections...the front connections are in the spindles, you'll see where the wires hook up. The rear hooks up to the differential somewhere. I had the same problem, pulled the front connectors off, sprayed them with contact cleaner, and no more problems.Wife and a dog, they both think they\'re Kujo.<br /> <br />1999 3.8 A4 Y87<br />Navy Blue Metallic<br />BFG G-Force KDWS 275/40/17s, <br />WS6 Wheels (17x9)<br />Phoenix Transmissions 2400 Stall Converter<br />FRA, Holley Powershot filter, Whisper Lid, Ported Throttlebody<br />2000 manifolds, Flowmaster, WS6 Tail Pipes, <br />MSD 8.5mm Wires, MSD Coils, Autolite plugs<br />Performance Cryogenics treated rotors<br />1LE Sway Bars and panhard rod, 1LE front springs w/SLP Bilsteins, stock rear springs w/ 3rd Gen Bilsteins, BMR STB, KBDD SFCs, 1LE rear lower control arms, 1LE front lower control arms<p>1968 Chevelle Malibu 327 TH350
Check the ABS sensor wires cause that will cause it to do so. My light came on for a long time and the low trac light. I got new brake pads and everything has been good ever since. Just take it to a brake place and see what they can do!<a href=\"http://www.saintsworth.com/z06\" target=\"_blank\">\'02 Corvette Z06</a>
Check your battery and alternator connectiosn, watch your amp guage.
Its completley unrealted, but everytime I ever had a battery, alternator or battery and alternator connectoin problem the abs inop light comes on. It hink its a failsafe toshut the abs system down to ensure the car has enough charge to keep the car running. I can think of at least 8 times wehre I had this problem all of them was unrelated to brakes, jsut the alternator, battery, or the connections between them, is definetly worth looking into.
<blockquote>quote:</font><hr>Originally posted by MustangEater8251:
Its completley unrealted, but everytime I ever had a battery, alternator or battery and alternator connectoin problem the abs inop light comes on. It hink its a failsafe toshut the abs system down to ensure the car has enough charge to keep the car running. I can think of at least 8 times wehre I had this problem all of them was unrelated to brakes, jsut the alternator, battery, or the connections between them, is definetly worth looking into.<hr></blockquote>
Yep, the first light to appear when the alt is going is generally the ABS light. If it stays on you'll soon be driving on allbattery for a very short period.94 Quasar Blue Z28<br /><a href=\"http://www.9t4z28.com\" target=\"_blank\">http://www.9t4z28.com</a><br /><a href=\"http://www.9t4z28.com/Dyno1.htm\" target=\"_blank\">http://www.9t4z28.com/Dyno1.htm</a>
by 2.8 BirdI wish you guys the best for you and your family. Good health, happiness and prosperity. Merry Christmas and a happy new year....7 hours ago
by ssms5411Just ordered some Toyo 315/35/17 tires for my 17x11 rims. Hopefully I can get them on the beginning of next year. Will post pics.9 hours ago
by ssms5411Haven’t done anything on the Camaro, but put LEDs on my truck headlights . And my oil pressure sensor went out on the truck so going to fix that this...1 week ago
