every time i hit a bump the rear end makes all kind of noise, it's really getting to me. can it be the sway bars or what.
can sway bars squeak
yep they can, but lot of things can cause that sqeuk. I list the easy ones.
could be toehr things, first, make sure your spare is not jsut rubbing aginst some metal to make the sqeuk.
next check the little black rubber screw looking things that are on the hatch, make sure they are adjsuted right and not ripped apart if so replace them I think I got mine for $0.50 a piece.
Next consider putting soem electrical tape around the latch on the hatch to prevent that form sqeuking.
?Next jack car up take off rear wheel and look above it ther should be a rubber bumpstop that the axle will hit if the car bottoms out, these things are known to rot and fall off, new one is like $12 at gm dealership.
next is use silicone grease to greae up your sway bar bushings, but I doubt this is whay is causing the sqeuk.
i have done all those things and the squeaks continue. i don't know what it is. they are getting worst though. could it be the poly bushings on the lca's and the panhard rod..97 Camaro RS<p>Big stall converter, Big fuel pump, Big cam and alot of nitrous
did you replace your shocks by any chance recentlY?94 Quasar Blue Z28<br /><a href=\"http://www.9t4z28.com\" target=\"_blank\">http://www.9t4z28.com</a><br /><a href=\"http://www.9t4z28.com/Dyno1.htm\" target=\"_blank\">http://www.9t4z28.com/Dyno1.htm</a>
<blockquote>quote:</font><hr>Originally posted by jersey:
could it be the poly bushings on the lca's<hr></blockquote>
Bingo...the LCA's with poly bushings will transmit a lot of squeaking, especially in cold weather. Mine squeaks a lot too for the first few minutes of driving.- Josh<br />If you have any questions or need installation pics/help, e-mail me: Viper98885@aol.com<br /><a href=\"http://Camaroz28.cardomain.com/id/viper98885\" target=\"_blank\">\'93 Camaro Hardtop</a><br /><a href=\"http://Camaroz28.cardomain.com/id/01lincolnls8\" target=\"_blank\">\'01 Lincoln LS8 Sport</a><br />\'00 Yamaha YZF-R6<br /><a href=\"http://www.ftpp.net\" target=\"_blank\">Full Throttle Performance</a>
by 2.8 BirdI wish you guys the best for you and your family. Good health, happiness and prosperity. Merry Christmas and a happy new year....8 hours ago
by ssms5411Just ordered some Toyo 315/35/17 tires for my 17x11 rims. Hopefully I can get them on the beginning of next year. Will post pics.10 hours ago
by ssms5411Haven’t done anything on the Camaro, but put LEDs on my truck headlights . And my oil pressure sensor went out on the truck so going to fix that this...1 week ago
