i think my front passenger side shock is unmounted. i checked it out and can't see anything obvious that would cause the noise i hear coming from it everytime i go over a bump. i think that it's the shock because my 82 t/a had a rear shock come unmounted, and it sounded exactly the same as this. unfortunately for that car, i couldn't even find anyone to fix it because it would have required them to take out the gas tank. anyway, is there anyway i can check myself to see if this is the problem? any suggestions about getting it fixed? thanks
unmounted shock question
Well if your shock has come unmounted, more than likely it would render the car undrivable. Two things to check for when hearing those noises are ball joints (upper and lower) they make lotsa noise when they're going out. And the mounting rivets on the upper ball joint. There are three rivets that secure the upper ball joint to the upper a-arm. This is a common problem on f-bodies and they make a lot of noise when they're worn. If you do a search you should find a good bit of info on the subject.1993 Camaro 3.4L A4 many mods comin for 2004<br /><br />\"The last thing I wanted was to get in a fight in Jackson, Mississippi on a Saturday night\"
by 2.8 BirdI wish you guys the best for you and your family. Good health, happiness and prosperity. Merry Christmas and a happy new year....8 hours ago
by ssms5411Just ordered some Toyo 315/35/17 tires for my 17x11 rims. Hopefully I can get them on the beginning of next year. Will post pics.9 hours ago
by ssms5411Haven’t done anything on the Camaro, but put LEDs on my truck headlights . And my oil pressure sensor went out on the truck so going to fix that this...1 week ago
