Polyurethane bushings?? - FirebirdV6.com/CamaroV6.com Message Board
  • Polyurethane bushings??
    I am looking into a full replacement of all rubber on the suspension... what will I notice different wiht the polyurethane set??? Thanks
    Squeaks! But it will be tighter.
    Raven
      i put them on mine there is a slight noticable diffrence i dont know what i would do with out them they help me out alot on the auto cross track
      •)))2000 3.8L V6 FIREBIRD (Navy Blue) 5 speed <br />•Aluminum Alloy 3-piece custom built wheels - 17x10 (front)- 17x11.5 (rear) Tires:Front: 275/40-17 - Rear:315/35-17• Suspension Techniques 1 3/8 \" Solid front Sway Bar• H&R Springs • Koni revalved double adjustable shocks (front)• Bilstien Custom Revalved shocks (rear)• K&N •Magna Flow Dual Exaust• Stock wheels W/Hoosier Road Racing tires • Sound System•<br /><a href=\"http://www.cardomain.com/id/o0oskamo0o\" target=\"_blank\">•THE RIDE•</a>
        Note that you don't want them on both ends of the lcas. They need to twist a bit when the car rolls in a turn.
          <blockquote>quote:</font><hr>Originally posted by V6Bob:
          Note that you don't want them on both ends of the lcas. They need to twist a bit when the car rolls in a turn.<hr></blockquote>
          If you use the stock LCA, you can and should use them on both ends, as the stock LCA is designed to twist and avoid suspension bind. I would NOT recommend poly/poly on a tubular LCA as they DO NOT twist.
          Raven
            <blockquote>quote:</font><hr>Originally posted by FirebirdGT:
            If you use the stock LCA, you can and should use them on both ends, as the stock LCA is designed to twist and avoid suspension bind. I would NOT recommend poly/poly on a tubular LCA as they DO NOT twist.<hr></blockquote>
            This is what I am doing...poly on both ends with the stock arm. Seems to work great.
            Also, listen to V6Bob and FirebirdGT on suspension suggestions....you will be happy in the end.
              For strickly straight line traction, what would benifit more:
              tubular LCAs with poly/poly
              tublar LCAs with poly/rubber
              1LE with harder rubber
              stock LCA with poly/poly
              Money is an issue, I'm looking for the most cost efficient way to solve this. I'm trying to get rid of my wheel hop and traction issues.
              Thanks for any input
              1996 Silver Camaro, Y87, M5, cammed..<br />N/A Best Time: 14.012 @ 98.59<br />195 rwhp / 233 ft-lbs b/f heads/cam<br />Check out my site <a href=\"http://silver3800.cz28.com/\" target=\"_blank\">http://silver3800.cz28.com/</a>
                <blockquote>quote:</font><hr>Originally posted by jonny985:
                <hr></blockquote>
                None, boxed Hotchkis LCA with poly/poly.
                Or the SLP reinforced stock LCA with ES poly bushings.
                I have NEVER recommended the use of welded tubular LCA.
                [ September 19, 2002: Message edited by: FirebirdGT ]</p>
                Raven
