what is the differance between Eibach, Hotchkis and H&R lowering springs.
lowering springs?
This topic is closed.
so i did some research and this is what i found out.
H&R 20% to 30% stiffer then stock 1.3 drop in front 1.4 in rear
Eibach 15% stiffer then stock 1.2 drop front and rear
Hotchkis 285-525lbs in front 100-140lbs in rear 1 drop front and rear
for some reason eibach and H&R dont give out spring rates.1998 green camaro, bear rotors.<br />It\'s not how much money you have, It\'s how many toys you have.
From Dominic's website
http://www.angelfire.com/my/fastcar/suspension.html~Derrick <a href=\"http://www.appstate.edu/~do54457/\" target=\"_blank\"><i>My Webpage</i></a><br /><b>\'96 3.8L V6 M5 Firebird Y87</b> | <b>162.8 RWHP</b> / <b>196.7 RWTQ</b> <br /><b>•</b> SLP CAI <b>•</b> <a href=\"http://tech.firebirdv6.com/y87.html\" target=\"_blank\"><b>Y87</b> Package</a> - 3.23s <b>•</b> 180º thermo w/ fan switch <b>•</b> TB spacer from DEE<br />1991 Jeep Cherokee Laredo 4x4
by DoodlerHi, everyone. We bought a 97 base model convertible Camaro and someone broke the motor ... Lights were blinking on the dash and that someone ignored the...13 hours ago
