<blockquote>quote:</font><hr>Originally posted by Seppo Kaitainen: In the recent yrs the actual 1LE sways have been 35/21. Thats the set up I plan on running on my TA.<hr></blockquote>
Sorry, no.
GM never offered a 35mm front sway bar, and the 21mm rear ONLY came on the 93 1LE which had stock V8 springs.
<blockquote>quote:</font><hr>Originally posted by FirebirdGT: Sorry, no.
GM never offered a 35mm front sway bar, and the 21mm rear ONLY came on the 93 1LE which had stock V8 springs.<hr></blockquote>
My mistake, your right. The SLP 1LE was 35/21.
Keith - 99 'maro - White M5 - bumpstick and boltons - 13.65 @ 101 N/A
"I ain't too big to listen to the rumors, I'm just too @#$% big to pay attention to them" - Dr. Dre http://seppo.hopto.org/
<blockquote>quote:</font><hr>Originally posted by FirebirdGT: Sort of - the 35mm was used on the SLP suspension package RPO Y2Y, which came with Bilsteins and custom SLP springs. http://www.slpeng.com/2002firehawk/index.html
[ September 20, 2002: Message edited by: FirebirdGT ]<hr></blockquote>
The 35/21 came on both level one and level two suspensions(aka "1LE") on the SLP cars. It would be interesting to find out why the SLP 1LE was different than GM's.
"It would be interesting to find out why the SLP 1LE was different than GM's."
35/21 (1.66) and 32/19 (1.68) are pretty close. In order to understand what the difference is you're going to need the inner diameters of the hollow bars and the spring rates.
The SLP bars are probably stiffer (the inner diameter thing could create a surprise, but it's not likely), so would work a bit better on dry pavement or at high speeds while a softer setup would be better in rain or at slower speeds.
The 35/21 came on both level one and level two suspensions(aka "1LE") on the SLP cars. It would be interesting to find out why the SLP 1LE was different than GM's.<hr></blockquote>
I don't know where you are getting your info, but the Y2Y suspension is NOT aka 1LE.
Although the SLP 1LE and Y2Y use the 35/21 they differ in spring rate and shocks. BTW the 35mm is not a GM part, but SLP.
SLP Y2Y -> level one -> Bilstein package
SLP 1LE -> level two -> 1LE package
My point was just that SLP's 1LE is not the same as GM's 1LE. Maybe b/c a differnce in wheel/tire size?
<blockquote>quote:</font><hr>Originally posted by V6Bob: "It would be interesting to find out why the SLP 1LE was different than GM's."
The SLP bars are probably stiffer (the inner diameter thing could create a surprise, but it's not likely), so would work a bit better on dry pavement or at high speeds while a softer setup would be better in rain or at slower speeds.<hr></blockquote>
So, going back to the original post's question: Wouldn't 35/19(1.84) be the best choice if you have 28/15(1.87) and stock springs/shocks from the factory??
[img]graemlins/burnout.gif[/img]
1999 Pewter Camaro M5<br />Y87 Performance Package, Sport Appearance Package, Diamond Clears<br />Factory SS Hood, Free Ram Air Mod, Whisper Lid w/ K&N Air Filter<br />CarSound Cat 94009, B&B Tri-Flo w/ Quad Tips<br />BMR SFC, BMR STB, KVR Blank Rotors, Hawk HPS Pads<br />Black Painted Calipers w/ CAMARO Decal, 245/50 Dunlop SP Sport 5000<br />20% Rear 35% Side Tint, Red Reflective Inlays, Invincishield<br /><b>Young girls avert their eyes, weak men tremble, Ford dealers faint.</b>
<blockquote>quote:</font><hr>Originally posted by F1GT:
[img]graemlins/burnout.gif[/img] <hr></blockquote>
Yes, 35/19, or 32/19 would probably be about the same, as long as the 35mm bar is a hollow bar, not solid. If the 35mm bar is solid (I'm not sure if SLP's is), then it's a whole different ball game.
Wife and a dog, they both think they\'re Kujo.<br /> <br />1999 3.8 A4 Y87<br />Navy Blue Metallic<br />BFG G-Force KDWS 275/40/17s, <br />WS6 Wheels (17x9)<br />Phoenix Transmissions 2400 Stall Converter<br />FRA, Holley Powershot filter, Whisper Lid, Ported Throttlebody<br />2000 manifolds, Flowmaster, WS6 Tail Pipes, <br />MSD 8.5mm Wires, MSD Coils, Autolite plugs<br />Performance Cryogenics treated rotors<br />1LE Sway Bars and panhard rod, 1LE front springs w/SLP Bilsteins, stock rear springs w/ 3rd Gen Bilsteins, BMR STB, KBDD SFCs, 1LE rear lower control arms, 1LE front lower control arms<p>1968 Chevelle Malibu 327 TH350
