so my front rotors have grooves it seems like. not sure they have ever been replaced and my car has close to 100k on it. what mileage u suggest i should replace them at? I have noo signs of needed anything new either, everything is working just fine......and ive heard of places sanding the rotors down to eliminate the grooves but if im gonna do a rotor job im just gonna replace the entire rotor....any suggestions would be great
how can i tell??
Depending on the rotors and how deep the grooves are, you can have them turned. They will put them on a brake lathe and cut them down until they are smooth. The rotors will have a minimum thickness measurement stamped into them, so don't worry about them getting cut too thin - the lathe operator will measure them after he cuts them. You can get this done at any brake/muffler shop and just about any auto supply store. If you have the rotors turned (or if you replace them) make sure you get new pads.<b>Mike</b><br /><a href=\"http://www.cardomain.com/id/mcjoslyn\" target=\"_blank\">2001 Camaro</a><br />Light Pewter Metallic Convertible<br />AU0,A31,C60,DG7,F41,GU6,K34,L36,M30,T82,T96,UN0<p ><b>If it can\'t be expressed in figures, it is not science; it is opinion.</b>
