Once upon a time my car hit a curb while cornering (lost traction). I had to have the axle replaced. Ever since then, there is a clanking noise in the rear of the car. It is noticeable only when I hit a bump. Also, I was checking it out the other day, and I noticed the panhard rod was bent. Is it supposed to be straight, should I replace it? Any help in diagnosing this would be appreciated.
Noise/Panhard rod
Are you talking about the upper or lower PHR?
The lower one is straight, the upper is bent.2002 5-spd NBM Camaro
Details: www.1lev6.com
and the stock PHR is u shaped.. You mean bent like you take a pipe and bend it in half or bent like its not a circle??Jeff ..
1998 Firebird.. Built 3.8 with a 125 shot.. 370rwhp,415rwtq.. stock tune!! sold
2002 WS6 T/A.. Bolt ins..448rwhp
2009 G8 GT.. Vararam intake, GXP axleback
1998 Corvette.. Vararam intake, Ti axleback
http://www.fquick.com/slow-v6
i bent my axle, lower PHR, and LCAs. I replace all of the above. The lower PHR IS supposed to be straight. I know that for a fact, because i put it in. I have replace my axle, lower PHR, and LCAs, when i hit LARGE bumps, i here a clanking noise coming from the rear right. so if yurs is the same noise as mine, replacing the PHR prolly wont fix it, but you NEED to replace it anyway. Check your torque arm aswell, i think mine was bent in the accident and is still bent but im not sure. that bent bar is yur PHR, its supposed to be straight....-christopher h<p>parting out v6 camaro. <p><a href=\"http://www.camarov6.com/cgi-bin/ultimatebb.cgi?ubb=get_topic&f=8&t=004216\" target=\"_blank\">http://www.camarov6.com/cgi-bin/ultimatebb.cgi?ubb=get_topic&f=8&t=004216</a>
