I would like a panhard bar, should i get adjustable or non and which ends? i also want lower control arms should i get tubular or boxed and which ends? is chromeoly worth it? what else should i get for drag racing? i dont want any suspension that makes a ton of noise either, thanks
whats the best suspension for drag racing?
Longtubes, true duals, ram air, caspers tps tec, ls1 26lb injectors, supersix powerpack, heads milled .020, comp cam .507 220/224 114 ls, forged internals and chromeoly pushrods, bored .030 over, tb spacer, tranny built with stiffer springs and kevlar bands, bigger servo, transgo stage 3 shift kit, edge 3600 stall, 1 pc aluminum ds, 3.73 superior gears, lsd rear ,custom pcm tuning, walbro 255 in tank,Tags: None
just drag racing, poly ends will be fine. adj. phr for lowered cars. phr is more for cornering than drag racing. billet aluminum or chrome-moly for weight reduction. for a more streetable car, rubber/poly combo bushings would be good, or rod-end setups, but rods tend to be louder.2001 Arctic White Firebird<br />More mods than I\'m allowed to list!
The things which affect drag racing in a good way:
A Big rear swaybar
Nice LCAs, poly is fine
Torque arm might help
No front swaybar
Soft springs with plenty of travel (old V6 ones work nicely).2002 5-spd NBM Camaro
Details: www.1lev6.com
i was gonna say stock springs make the car squat nicly off the line and get better traction, or at least thats what i tell myself [img]graemlins/burnout.gif[/img]
b/c now i have lowering springs on and it spins more when i gun it, even w/ 315's in the rear.1999 White Ford SVT Lightning.<br /><br />Hoping to dyno @ 450hp/550tq by the end of \'04.
"The things which affect drag racing in a good way:
A Big rear swaybar
No front swaybar
Soft springs with plenty of travel (old V6 ones work nicely)."
Uhh, Dominic...
I think that, for most people on this board, "drag racing" means they take their only street car to the strip occaisionally.
Given that, you might at least mention that driving a car on the street with exactly that setup borders on insanity. It's a fine setup for a pure drag car.2000 Firebird convert, chameleon/tan, M5, Y87, TCS, BMR tower brace and panhard, KBDD sfcs, 245/50-16 GSCs
Get LCAs. Boxed if you want to be serious and don't care if your suspension binds in turns, or 1LE if you want all around performance.Matt<br />2000 Firebird<br /><br /><a href=\"http://www.fullthrottlev6.com/forums/index.php?\" target=\"_blank\">FullThrottleV6.com</a>
My 2.0 60' on street tires was with 1LE LCA's, no other suspension mods.
My 1.8 60' on ET streets, also 1LE LCA's only.
Both on the stock converter too.\'98 A4 Camaro v6->v8 conversion, and STS kit next<br />v6: 13.6 Powerdyne, 13.2 150 shot, 13.8 120 shot, 14.3 85 shot, 15.7 stock<br />v8(na): 12.18@113, 392rwhp<br />Moderator on <a href=\"http://www.mtfba.org\" target=\"_blank\">www.mtfba.org</a> and <a href=\"http://www.frrax.com\" target=\"_blank\">www.frrax.com</a> (Road Race & Autocross)<br /><a href=\"http://community.webshots.com/user/johnduncan10\" target=\"_blank\">Car pics</a>, <a href=\"http://www.trscca.com\" target=\"_blank\">TN Region SCCA</a>
where do i get the 1le stuff and does anyone have any part numbers? isnt 1le kinda like whats on a stock v8? if so wouldnt bmr be better or stronger?Longtubes, true duals, ram air, caspers tps tec, ls1 26lb injectors, supersix powerpack, heads milled .020, comp cam .507 220/224 114 ls, forged internals and chromeoly pushrods, bored .030 over, tb spacer, tranny built with stiffer springs and kevlar bands, bigger servo, transgo stage 3 shift kit, edge 3600 stall, 1 pc aluminum ds, 3.73 superior gears, lsd rear ,custom pcm tuning, walbro 255 in tank,
The control arm itself is not really compressing on launch. The bushings are. The 1LE bushings are much stiffer and control that compress/unload oscillation that leads to wheelhop.
The part number is in the tech database. Some of our sponsors can probably get it for you (I got some 1LE stuff from Leon at lmperformance), and www.gmpartsdirect.com definitely can get it.
In my earlier note, I said no other suspension mods, but I did have the 1LE swaybars. I don't think they contributed much, if anything, to the drag launch though. Just wanted to correct my suspension comment...\'98 A4 Camaro v6->v8 conversion, and STS kit next<br />v6: 13.6 Powerdyne, 13.2 150 shot, 13.8 120 shot, 14.3 85 shot, 15.7 stock<br />v8(na): 12.18@113, 392rwhp<br />Moderator on <a href=\"http://www.mtfba.org\" target=\"_blank\">www.mtfba.org</a> and <a href=\"http://www.frrax.com\" target=\"_blank\">www.frrax.com</a> (Road Race & Autocross)<br /><a href=\"http://community.webshots.com/user/johnduncan10\" target=\"_blank\">Car pics</a>, <a href=\"http://www.trscca.com\" target=\"_blank\">TN Region SCCA</a>
<blockquote>quote:</font><hr>Originally posted by V6Bob:
A Big rear swaybar
No front swaybar
Uhh, Dominic...
<hr></blockquote>
Good point, I agree. I would never drive a car setup like this... but if you're a die hard and trailer your V6 [img]graemlins/rofl.gif[/img] ... well you get my drift.2002 5-spd NBM Camaro
