whats the widest tire that will fit stock 16's? - FirebirdV6.com/CamaroV6.com Message Board
  • whats the widest tire that will fit stock 16's?
    my tires are pretty worn out, i have 245/50/16's on the back and 235's on the front
    they're the stock 5-spoke alloy wheels
    what's the widest tire that will fit the wheels?
    mcG<br />aim=endlive<br /><a href=\"http://www.cardomain.com/id/endlive\" target=\"_blank\">97 firebird</a> ~ wrecked
    255 has been proven
    •)))2000 3.8L V6 FIREBIRD (Navy Blue) 5 speed <br />•Aluminum Alloy 3-piece custom built wheels - 17x10 (front)- 17x11.5 (rear) Tires:Front: 275/40-17 - Rear:315/35-17• Suspension Techniques 1 3/8 \" Solid front Sway Bar• H&R Springs • Koni revalved double adjustable shocks (front)• Bilstien Custom Revalved shocks (rear)• K&N •Magna Flow Dual Exaust• Stock wheels W/Hoosier Road Racing tires • Sound System•<br /><a href=\"http://www.cardomain.com/id/o0oskamo0o\" target=\"_blank\">•THE RIDE•</a>
      Yup, 255 50's in all four corners at one point
        I have 255/50/16's on the Z in the link below and thery were on the V6 before that.
        94 Quasar Blue Z28<br /><a href=\"http://www.9t4z28.com\" target=\"_blank\">http://www.9t4z28.com</a><br /><a href=\"http://www.9t4z28.com/Dyno1.htm\" target=\"_blank\">http://www.9t4z28.com/Dyno1.htm</a>
          I was looking around summit racing, and they say that a 295 can fit on an 8 inch rim. They have BFGoodrich Radial T/A tires that are 295/50/16 (bigger tire, so you would lose some torque) that can fit on a rim between 8 and 10 inches wide.
          I am considering these now (rear only), because then I can switch to 3.42's and not throw my speedo off. (3.42's knock my speedo of about 5.8%, these tires kick it back the other way 5.5%, making a total difference of .3%)
          I am also thinking maybe I should go with these and a 3.73 gear, because it would be closer to me swtiching from 3.23 to 3.42, because the tires offset a bunch of the error.
          Either way, when I hit the track, I can put some smaller (not too much thinner, though) tires on and have a nice change in gear. Then, when I put the big guys back on for normal driving, the gears are closer to normal.
          What do you guys think?
          All gone :(<br />Best ET ever: 14.3 (I think)<br />----------------------------<br />Check out my site for exhaust clips, burnouts, and pictures, and the supercharger throttle body mod.<br /><a href=\"http://www.geocities.com/net_addict/index.html\" target=\"_blank\">Click on the Firebird</a>
            If you get those 295s to fit on the stock rim, it's gonna look like you're riding around on big black balloons. I would be so scare of the tire separating from the rim at that size.
            <b>1998 Firebird 3800 Series II, A4</b><br />Direct-Flo Lid,K&N Filter,DEE TB Spacer,TPS-TEC,ZZP Mini-AFC,Raised and Cutout Airbox 7mm,BMR STB & Boxed LCAs,KYB AGX Shocks,Drilled/Slotted Rotors,180* Thermo,2.5\" Catco Cat,Dynomax 2.75\" custom catback,Kumho Ecstas/245,Jet Stage 2,3.42,Edge Racing 2870 Stall,B&M Tranny Cooler,B&M Deep Tranny Pan,LSD,AAM Girdle,1LE DS,NX Wet Kit,MSD DIS-4,MSD Blaster Coil Packs,Taylor Spiro Pro 8mm Wires,NGK TR6\'S gapped .045,ZZP UD WP Pulley,SLP Fan Switch,TT II\'s<br />N/A: 15.6342 @ 88.44 (On stock converter. Strugglin\' to beat it.)<br />Nitrous 50 Shot: 14.7463 @ 93.49
              "POING!!! FLAP,FLAP,FLAP,FLAP SQUEEEEL, BANG!!!"
              If you put 295's on your stock 16" rims, that's the sound you'll hear eventually when the tires separate from the rims. I would advise against it.
              [img]smile.gif[/img]
              1997 Y87 Camaro with a motor and some stuff.
                295/50? That is a typo.
                255/50 is the widest our 16x8" wheel can handle in a DOT legal tire. P265/45 and wider have been run in the past using Kumho Victoracers, but they have a far different sidewall composition which allows for the mismatch in width to work okay.
                2002 5-spd NBM Camaro
                Details: www.1lev6.com
                  295/50 might fit on an 8" wide rim, but that's speaking of a drag tire, that has a totally different sidewall (which I don't think will be DOT legal). A normal 295/50 street tire would pop off an 8" rim. Also, with a sidewall that tall on your 16" rim, I'm almost positive the tire would rub the fender on the launch if not always. My 275/50/15 drag radials cut it close.
                  -<i>Travis</i><br /><b>99 Trans Am, Pewter, A4</b> Forged, stalled, and cammed<br /><b>85 Buick Regal WH1 T-Type</b> It\'d be cool if it ran...<br /><b>94 Camaro 3.4, Teal, M5</b> The daily beater
