What aligment angles change when i go from 215/60/16 to 245/50/16. I installed 245s and now my car seem to wonder more, like it doesnt pull to one side or another but kinda wonders around while going straight. Also, if theres a crown on the road, it will want to dive in it, so i have to hold the steering wheel with both hands.
245 question
The alignment doesn't change at all.
You have discovered the major drawback of low profile tires, when you went from a 60 to a 50. They follow road irregularities more. It is why they are used more on performance cars than on touring or luxury cars.
You may have had a marginal alignment to start with, which was not affecting the 60 series tires as much. So, a complete alignment, to factory specifications, may help. But I would guess it's mostly the 50 series tires.2000 Firebird convert, chameleon/tan, M5, Y87, TCS, BMR tower brace and panhard, KBDD sfcs, 245/50-16 GSCs
Honestly, for some strange reason, my stock 235-55-16's followed ruts in the road a heck of alot more than my 255-50-16's I have now. I thought that by getting lower profile and wider tires it would be much worse, but it got better:D
-Marcsigpic
the wider the tire the fewer ruts it can fall into.
a 5 inch crack would be devastating to a 5 inch tire. A 10 inch tire wouldn't even know the crack is there.<b>15.41</b> @ 89.80 & 15.45 @ <b>91.64</b>, 2.21 60ft, 3,440 raceweight, using <b>OEM</b> Equipment. <br />\'98 L67/M49 w/ 134,000 miles before spun bearing. \"<i>It\'s all stock, Baby</i>!\"
