brake help PLEASE - FirebirdV6.com/CamaroV6.com Message Board
brake help PLEASE
  • brake help PLEASE
    EXACTLY how do you change the brake pads on these cars......with antilock,can you just push the pistons back in the caliper? ...or is there more to this? do you remove the lid to the master cylinder or leave it on....i would like cerrect info please...as im new to antilock replacements...
    also...anything i need to know about the rear brakes? THANKS MUCH
    I did the front discs, it's just like changing regular breaks pretty much. You just take a clamp and push that little piston all the way back throw on the breaks and do it like a normal break job.
    Ted
      http://eric.virginia.com/install_uni...ds_mwarren.htm
      everything you need to know about changing the brakes.
      Kyle M<br />--------------<br /><a href=\"http://grdws6.netfirms.com\" target=\"_blank\">2002 Trans Am WS6</a> (silver, A4) - lid, cutout, stage 3 shift kit, 12 bolt, vig 3200, tranny cooler, bmr sfc/stb, torq thrust ii. <b>12.688 @ 106.47mph -=- 1.756 60\'</b>
        perfect ....thank you very much for the info...i need pads and rotors are warped...lucky me
