All right when I'm going down the road about 60-65 my car starts shaking kinda bad I mean not so bad that it gives you whiplash but the steering wheels shakes some and you can fell the vibraating through the seat I can slow down to a creep and feel the car wobble what could this be I wrecked the car once when I went out of control and jumped the ditch and hit a field with my front end I got it fixed. Also my cars pulls a little to the right but it always has you guys don't think that my rim actually bent do you? Please help cause I don't know.
thanks,
Mike
94 Camaro a-4<br />Z-28 Exhaust<br />gutted cat<br />Just not enuff!
had the same problem went to the shop this morning. Where I went it was 40 for the alignment and 6 bucks a tire for balancing. Car drives so much better. here's some info alignment info
-Brad
2000 V-Star Custom 1100
:rock:
I have the EXACT same problem. I got 2 new front tires and everything rotated and balanced and it still does it but not as bad. I really need new back tires. My front left lower ball joint seal is broken.. thats why I don't trust shops. [img]graemlins/thumbsdown.gif[/img]
1995 Patriot Red T-Topped Z28 A4<br /><br />Mystery rebuild in progress.<br /><br />Soon to have 383 ways to beat KBreezy and Shane. :D
If it is when your braking its your rotors. Mine are warped bad i have gotta get new ones.
AIS 2 OHH the memories... Great times and putting names with faces.<p>From \"interesting\" hooters waitress(Did you guys FLY ? ) to pissing BMW owners off on the ride home. To ending up in Philidelphia and USING (hahaha) an ice machine. I had a BLAST.<p>Thanxs to all that showed up!!
If it vibrates a a high speed, and you can speed up or slow down and it goes away then its your wheel balance. If it vibrates at low/all speeds then you have a tire or wheel problem. If you wrecked it I would get aligment too. Take it to a tire shop and tell them whats happening. They'll take good care of you (if they want your money). If you have some dough to spare get the computer match mounted. I did it. They get put on the wheels so that they provide the best ride. It costs big bucks though and if it wasn't free i probably wouldn't do it. Those are some options, hope that helps.
1997 Dodge Viper GTS
