Wider tires = BAD ?? - FirebirdV6.com/CamaroV6.com Message Board
  • Wider tires = BAD ??
    Ok my car is supose to have 215-60-16. I want 255-50-16. Can you give me any possible con to haveing these size tires versus the stock ones besides
    1 speedo will be off a litle do to smaller sidewall ( thats ok w/ me)
    2 car will wonder more (thats ok w/ me )
    3 will sling more junk onto the side of my car( i wash it religously thats no problem)
    i cant think of anymore reasons why not to get the wider tires my dad said that they would rub when i turned and that the wider tire will put more strain on the wheel bearings???? is this true to any extent. I have a 96 bird w/ 16x8 inch alloys.
    AIS 2 OHH the memories... Great times and putting names with faces.<p>From \"interesting\" hooters waitress(Did you guys FLY ? ) to pissing BMW owners off on the ride home. To ending up in Philidelphia and USING (hahaha) an ice machine. I had a BLAST.<p>Thanxs to all that showed up!!
    The sidewall height of your 215/60 is 129
    The sidewall height of your 255/50 is 127.5
    They are actually lower profile.
    1997 Dodge Viper GTS
      Also you can put pretty wide tires on (see sig.) They don't rub at all. 275/40 17 is the biggest that fist on the front. I have no problems at all. No veering off or anything.
        more frictoin agianst the road when you are dirivng at the dragstrip.
          Yes...what MustangEater said is correct. Depending on how much power you have, wider tires could be hurting or helping you. You want to get the best launch with the smallest tire. Its a compromise but I dont have any info on which is best...I have 225's and they are fine with me.
          1993 3.4 <br />Borla rear section<br />3 inch Catco High Flow Cat<br />2.75 inch I pipe (Picked one up from an LT-1 guy for a whole $10)<br />K&N Fipk <br />180° T-stat<br />Jet Stage II<br />10 Spoke Z28 Wheels<br />NGK\'s, Taylor Spiros<br />Mobil 1 synthetic<p>Email Viper2@chesnet.net for 4th gen replacement parts.
            yeah you will have a bit of a trade off with the wider tire being more unsprung weight, there will be a little difference in turning radius as wider tires can hurt your low speed turning radius (ie parking lots and such) but you should get a little better grip for high speed cornering to make up.. other than that you should have no problem.. besides there is nothing like having a big fat set of tires under our cars.. really makes them look better!
            -Brad
            2000 V-Star Custom 1100
            :rock:
              too wide isnt always good. it depends on how much power your running. Im getting some 245/50's to replace my 235's. I was going to get some 255's but decided the 245's should be sufficient. [img]graemlins/burnout.gif[/img]
              [ March 18, 2002: Message edited by: marco ]</p>
              <b>.::[ 0 ]::.</b><br /><b>1997 Camaro 3800 II M5</b> (30th edition)<br />[]B&M Ripper Shifter<br />[]Proform Shift Light<br />[]SLP Cold Air<br />[]Dynomax Exhaust<br />[]Richmond 3.73\'s<br />[]Zexel-Torsen LSD<br />[]180* Thermostat<br />[]Tail Blackouts<br /><a href=\"http://photos.yahoo.com/skyracer_x\" target=\"_blank\">pics</a>
                I have BFG 255/50s, they work great. I went to them from 235s, it's noticeably more difficult to turn the wheel when you're not moving, but they don't rub, they do follow cracks in the road and such a bit more, but they also stick to the road a hell of a lot better. The speedo is off by just a tad, but not much, at 80mph with the 235s, it was running just under 2500, with the 255s, right at 2500.
                  I have 245/50 Bridgestone Pontenza RE-730's, i had the 215's stock, and those tires looked terrible, the 245 looks a lot better but i think a 255 would be over-kill, i would think the sidewalls would hang out too far, just my opinion but not positive
                  <b>Black</b> 1998 Pontiac <i>Firebird</i> A-4 swap<br />271.4rwhp/259.4rwtq NA<br />13.30@102.44 <br /><a href=\"http://www.freewebs.com/wickedsix98\" target=\"_blank\">www.freewebs.com/wickedsix98</a>
                    I have 245/45/17's in the front and 275/40/17's in the rear. They're strapped to 17x9.5" TT II's so with a wider rim, there is no over-hanging of the sidewall. Not even my 275's hang over. If anything, I don't think I'd get any over hang until a 305 came into play but I can tell you one thing...... with my 3.4, I noticed a performance difference instantly. It will hook up in a corner like a dream, however, you have to compensate with a bit more gas to keep your speed up or your speedo will DROP! On my stock salad shooters, I have 245/50 Falkens and I've got a little more pull and top end with those. The 3.4 will never be fast enough to my liking, so I'll just look good going slow until I get a new ride :D
                    1994 Camaro 3.4L M5 R.I.P.<br />You know what they say- a small engine means big... errr... e/t\'s<br /><a href=\"http://www.pbase.com/rrj72/the_accident\" target=\"_blank\">www.pbase.com/rrj72/the_accident</a><p>replaced with: red 97 A4 vert (my brothers as soon as i find my REAL replacement)<p>soon to come: 1969 RS/SS<p>\"All you need are the esentials: scented candles, massage oil, and Berry White write that down.\" -Van Wilder
