im getting a line lock in 2 days and im going to install it my self but i dont know how to do it because from what i know you cant let the brake lines go dry
line lock help
It comes with instructions... the basic idea is to let the fluid drip through the main line until it comes out before hooking it up, otherwise you'll end up needing to bleed the ABS module... not fun.2002 5-spd NBM Camaro
Details: www.1lev6.com
I had it installed.
I could not do it myself due to wiring involved.
Just an FYI the shop needed to bleed the brakes forever!!!!!!Race car - gone but not forgotten - 1997 firebird V6
Just installed one last night, we used the directions from Ls1database.com... all you have to do is make sure that the minimal amount of air is allowed in the lines... works pretty good too... Not on my car, that would be a bit overkill.... It was on a 11sec NA Z... badass car....
