Wierd noise - FirebirdV6.com/CamaroV6.com Message Board
Wierd noise
  • Wierd noise
    Two weeks ago i make a trip from tx to ny. well the last 200+ miles of the trip i started to notice this coming from both my back wheels/brakes/rotors/whatever. It was constant whether is was accerating or just coasting and the noise didnt change at all when i would brake. The faster my car travels the more noticable the noise. Well i thought it might be my brake pads so i changed them and noticed that my inside pad was only about an 1/8" thick, while my out side pad was at least 3/8" thick if not thicker, they almost looked new. And my car only has 30,000 miles on it. My brakes dont feel like theyre binding. I think that my e-brake is sticking even though the handles all the way down. Let me know what you think guys, thanks.
    _davjos81- 02 v6<br /><a href=\"http://www.cardomain.com/id/davjos81\" target=\"_blank\">www.cardomain.com/id/davjos81 </a><br /><a href=\"http://community.webshots.com/user/davjos81\" target=\"_blank\"> <a href=\"http://community.webshots.com/user/davjos81\" target=\"_blank\">http://community.webshots.com/user/davjos81</a> </a> <br /><br />-over $8,000 invested! Too many mods to list, just check out my site!!
    If the pads are wearing unevenly, the caliper isn't sliding. Pull the pins and clean and lube them. The easiest way to check the parking brake is to spin the hub and see if it is dragging with the brake off.
    <b>Mike</b><br /><a href=\"http://www.cardomain.com/id/mcjoslyn\" target=\"_blank\">2001 Camaro</a><br />Light Pewter Metallic Convertible<br />AU0,A31,C60,DG7,F41,GU6,K34,L36,M30,T82,T96,UN0<p ><b>If it can\'t be expressed in figures, it is not science; it is opinion.</b>
      i did spin the rotor, w/ the brake pads off and the ebrake off and i could still hear the noise, what could that mean?
        It probably means the pad is rubbing the disc. As long as it's not really dragging on it, it's not a problem. Lube up the caliper pins and try it again (after some driving).
