Will Vette calipers bolt up to ours? - FirebirdV6.com/CamaroV6.com Message Board
  • Will Vette calipers bolt up to ours?
    Have an opportunity to get some low mileage vette calipers, complete set. Will they fit on ours or no? I'd also upgrade the brake pads too. Thanks.
    Scott
    Fronts yes, I'm not sure about the rears though.
    Steve
    FirebirdV6.com/CamaroV6.com Administrator
    Stupid is rewarded with the ban button.
    Official Avatar Nazi according to Meatyshells :D
      Thanks Steve! Anyone know about the rears?
      Scott
        Will Corvette calipers really fit?? What is the difference compared to 98+ calipers. i thought they were both dual pistons??
        <b><i>1999 Pewter Trans Am M6 - Stock for now...<br />296.6 RWHP and 310.6 RWTQ</i></b> -<i>SOLD</i><p><i>\"There are vast amounts of money to be made in the sevice of the Lord!\"</i><br /><i>1994 Green Camaro M5 - <b>SOLD</b></i><p><br /><b><i>Associate of VENOM-VI</i></b>
          http://www.gmpartsdirect.com/performance_parts/store/catalog/Category.jhtml¿CATID=1 385.html
          look under racing brakes - basically vette calipers + info about them.
          I personally like the LS1 brakes, but if I could get a set of stronger calipers I definetly would.
          12559525 - Alum DriveShaft = $255 shipped. [img]smile.gif[/img]
          [ March 21, 2002: Message edited by: TheCardinal ]</p>
          2002 5-spd NBM Camaro
          Details: www.1lev6.com
            I would hold off from getting the vette calipers, depending on how much you are getting them for. Even though it may be more expensive the Baer or Wilwood brake systems are much better plus you have many different options on the type of calipers you can get. Such as 2,4, or 6 piston calipers plus you get larger rotors and everything comes in a kit or seperate dependent on your needs. The stuff may cost 600 dollars but ya got to figure in the cost of replacing your stock pads and rotors every couple of months as compared to the lasting effects of these other types of brake equiptment. Thats not to say that not to get the vette calipers if you can get them cheap of enough, but that its always good to know your options first.
            1994 Camaro<br />3.4L V6 Automatic<br />K&N FIPK&Gold Oil Filter,Ravin Performance Exhaustw/Dynomax MandrelBent3\"I-Pipe&S Pipe&Catco 3\" HiFlow Cat.,ASP Crank and High AMP Alternator,U.D. Pulley Set, Bosch Spark Plugs and Oxygen Sensors, Taylor Wires, B&M E.ShiftPlus, 160 thermostat,Zexel Torsen L.S.D., CSI Remote Mount Electric Water Pump & Temp. Controller & Flex Hoses, ALM. Drivshaft, Diamond SubFram Conn.<br />COMING SOON: 350 or 502 RAMJET ENGINE & Big Block Hood<br />NJ V6 F-Body Club<br /><a href=\"http://tristategm.com/NJFbV6/\" target=\"_blank\">http://tristategm.com/NJFbV6/</a><br />Street Lethal F-Body Association <br /><a href=\"http://www.slfba.com./index.html\" target=\"_blank\">http://www.slfba.com./index.html</a>
              What year is your car and what year are the brakes off of?
              Hot Cammed LT1 Sleeper
                1. Read my sig.
                2. They are off of a 99 vette.
                I pretty much don't think i'll do this, because it will be better long term to get slotted rotors and all that good stuff, etc.
                Scott
