Newbie Suspension Questions - FirebirdV6.com/CamaroV6.com Message Board
  • Newbie Suspension Questions
    Hey everyone, Im new around here. I just bought my 2002 Camaro V6 and am looking around for some ideas of what to do with it. I am a previous J-body owner, and I dropped that car 2", when I returned the car to stock form, the drop had ruined my struts. Will lowering a Camaro lead to the same problem, or are the stock struts/shocks strong enough to handle the drop? Also, I have heard some dissention about what's the best springs to buy, I hear alot about Eibach's being the best, but is there anything better for our cars? And where can I find the best prices on springs? Thanks alot!
    2002 M5 Camaro 3800<br />1LE Sway Bars<br />Hurst Billet Plus Shifter<br />3.23\'s<br />Ghetto Whisper Lid Mod<br />Ghetto Ram Air Mod<br />Taylor Wires<br />Holly Powershot Filter
    Yes if you lower your camaro it will ruin the stock shocks. If you want to lower then basically read the thread below and that should give you some ideas.
      When doing lowering springs, it is best to get a matched set of shocks along with them as well as a adj. rear panhard rod. The adj. panhard rod will allow you to recenter the rear axle from when it was uncentered by the lowering springs. This will allow you to have a good handling car that doesn't pull to one side when accelerating or has too much lean when cornering. Also is a must when wanting to put wider than stock rear wheels on the car.
      2001 Arctic White Firebird<br />T-Tops, 3.42 rear gear stock<br />Mods:K&N Air Filter,Whisper Air Induction Lid, maf screen removed, raised air box, Kumho Ecsta 712 255-50-ZR16 tires, BMR stb<br />Mods not installed yet: FTRA, SLP Lsd/Differential cover<br />Near Future Mods: HPP3, GMMG 3\" Exhaust , 1LE Swaybars, Transgo Shift Kit, MSD-DIS-4 w/ Accel Coil-Packs, Turquoise Blue Neon Underbody Kit, BMR Adj. LCA\'s, G2 Sfc\'s & V-braces, Pacesetter headers
        Will Bilsteins support a 1"-1.5" drop, or are they direct OEM replacements, that will wear out over time like the stock shocks? If they cannot be used w/ a drop what do you guys recommend? Thanks.
          <blockquote>quote:</font><hr>Originally posted by Patrick Javert:
          The adj. panhard rod will allow you to recenter the rear axle from when it was uncentered by the lowering springs. <hr></blockquote>
          Useless mod unless you have a real problem. The axle is never centered, and lowering only moves the axle by 1/4". Replace the PHR bushings from ES, or get a 1LE.
          Raven
            Robert - I liked this answer of yours better:
            "the rear axle looks to one side"
            As you know, I think anyone whose rear axle is _visibly_ misaligned could use one. Calipers are not necessary, IMHO.
