I was looking at my LCA's the other day, and i was wondering, why dont yall just strengthen them?? you could weld a strip of steel across the bottom and have a "halfass" boxed LCA that would probably work just as good as aftermarket along w/some polyurethane bushings???
Have any of yall strengthened the stock LCA's???
And then they would be just as lousy as the aftermarket junk. Read the Technical Database about suspension binding.Robert - owner www.FirebirdV6.com/CamaroV6.com
Raven
<blockquote>quote:</font><hr>Originally posted by TheBeast:
That's exactly what the SLP LCAs and Panhard rod are. I believe the 1LE is also the same?<hr></blockquote>
SLP sells 'reinforced' LCA's & Panhard rods, but they also come w/poly bushings. The 1LE stuff is not boxed, the only real changes from stock being better bushings & possibly heavier-duty stamped-steel construction.2001 Onyx Black Camaro M5-Totalled<br />2005 Ford F150 XLT 5.4L<br /><br />\"To make peace, prepare for war.\"
By welding on a piece on top of the stock LCAs, you minimize the deflection of the rear suspension. It's designed to allow flex from left to right. Boxing it in will result in minimal deflection. Thats bad. You're better off getting the 1LE's.Big cam. Big stall. Big nuts.<br /><br /><a href=\"http://www.streetlethal.net/vids2/joenastycam.MPG\" target=\"_blank\">Idle/Rev Clip.</a>
by ssms5411About a week ago noticed my brake lights not working also Hazards not working. Installed new brake switch and still not working, checked fuses and what...2 hours ago
