I Just put my SS rims back on, and it is riding really funny, it will pull to the right every time i slow down, and also at top speeds it doesn't like to go in a straight line, kinda moves around. I'm am going to get a tune up and front end looked at. Did anyone else have this problem when they went with bigger wheels and tires??? i have 275/40/17's on right now.
put my new rims on, got a question
Did you get the wheels balanced? Have your alignment checked, if you dont, your tires will start to wear on one side a lot more than the other.1993 3.4 <br />Borla rear section<br />3 inch Catco High Flow Cat<br />2.75 inch I pipe (Picked one up from an LT-1 guy for a whole $10)<br />K&N Fipk <br />180° T-stat<br />Jet Stage II<br />10 Spoke Z28 Wheels<br />NGK\'s, Taylor Spiros<br />Mobil 1 synthetic<p>Email Viper2@chesnet.net for 4th gen replacement parts.
Well, if it is always pulling to one side then it might be an alignment issue, but if it just "wanders" then it is probably just the tires following the imperfection in the road. Wider/performance tires are known for this. I know mine wander all over the place on crappy roads, just something to deal with. And yes, they do it more underbreaking.<b>Matt</b><br /><a href=\"http://www.cardomain.com/member_pages/view_page.pl?page_id=377225&page=1\" target=\"_blank\">\'96 Camaro Z28 M6</a><br /><a href=\"http://www.cardomain.com/member_pages/view_page.pl?page_id=377225&page=3\" target=\"_blank\">\'96 Camaro M5</a>
Try swappng the two front tires. If it still pulls to the right, you know it isn't one of the tires.
I had my alignment done recently and even after it was done there was still a slight pull. Swapped the tires and it went away. The shop called it a "radial pull". I have heard this before, but have always thought it was an excuse shops made up when they can't get a car to drive straight [img]tongue.gif[/img] But the swap did cure my problem so there is something to it.
Thanks guys,
Well i just found out how bad these tires are in the snow. my car is stuck in the parking lot of my work. oh well I guess I forgot about how crappy Ohio weather is. :(
[img]graemlins/fluffy.gif[/img]04 black comp G GTP<br />*sold* 2000 z28 6speed <br /><br /><a href=\"http://www.cardomain.com/id/extinctls1\" target=\"_blank\">http://www.cardomain.com/id/extinctls1</a>
i have a problem with my car pulling to the right, tires are balanced, and i just got a full alignment done, so could it be an imperfectoin in the tire?
thats what im thinking it boils down to is one tire grabs a bit more than the other since its all been recently balanced and aligned...
although i dunno how likely this is...R.I.P \'99 Firebird, you will be missed<p>New toy - 2001 GSXR-750, Yoshimura Exhaust, Power Commander, Rebuilt Airbox
Would 245 50r16's fit on the 94-97 ss rims?99 3.8 Camaro<br />Intake Mods: K&N filter, Whisper lid, free ram air, !air silencer, !maf screen<br />Exhaust Mods: Flowmaster 80 series, 3\" I-pipe, 3\" Cutout<br />Suspension: Intrax Springs (2\" drop)<br />Misc.: Fan switch mod, Hayden transmission cooler
by ssms5411Not much going on, replaced my Kenwood double din stereo with a Pioneer double din, the Kenwood had problems. Then replaced my power inverter for my reverse...4 weeks ago
