Difference with LT1 Steering Rack - FirebirdV6.com/CamaroV6.com Message Board
  • Difference with LT1 Steering Rack
    If i install an LT! steering rack with tighter steering, will i notice a big difference, or not a big one at all? Basically, is it worth is to take apart, and get front end alligned again?
    anyone?
      I am kinda wondering the same thing... My rack is actually going bad, so I was just thinking to put one of those in regardless. If I get mine in, I will let you know. I think it wont hurt anything, so might as well in my case. Good luck. ;)
      Jordan<br />15.09@90.7<br /><a href=\"http://www.fullthrottlev6.com/forums/vbgarage.php?do=view&id=21\" target=\"_blank\"><b>1995 Camaro 3.4 M5</b></a>
        i don't think that they're interchangeable. Ross could tell you, he's tried the swap before. As I recall, they are mirror images of each other.
        ╓<br />║ Matt M<br />║ <a href=\"http://home.austin.rr.com/morrism/3800/sunset_logo2.jpg\" target=\"_blank\">Down with the Sixxness</a> <br />║ Polo Green 1995 3.8 Camaro<br />║ intake, cat, catback, shocks, 3.42\'s, and 12\'s in the trunk<br />╙
          Oh. OK.
            It will work. Its a direct bolt up. The difference in the racks is the steering ratio, v8s and y87s have a tighter ratio (geared more towards performance) where as ours are a bit looser. I would order just order one from TA Creations for under a bill and let er rip. There's a guide if you search for it. Thanks.
            <b> \'95 Camaro 3.4L A4 <i>Rikku</i><br />AutoX - Drift - Street </b><br />\"Sideways is faster.\"
