Front end problem?? - FirebirdV6.com/CamaroV6.com Message Board
Front end problem??
  • Front end problem??
    The past few weeks ive noticed when accelerating from a stop and even at cruising speed there will be a loud pop coming from underneath my front end area, seems to be more towards the front passenger side, sometimes i can feel it on the floorboard also as if sometting is banging together, im just not too sure what it is, steering seems fine every thing like that, i also noticed it will do it when i make turns sometimes but not all the time, if anyone has an idea what it might be or had a similar problem any help would be great thanks.
    ~~99 Camaro 3.8 A4 Y87~~<br /><br />\"yeah I got mods\"
    sounds like your tranny mount is bad
    www.turbov6camaro.com
    1997 3800 Series II Camaro
      i have the same problem i thought that it was my tie rod ends cause the bushings were shot.
      1996 Metalic Bule Camaro: no cat BORLA muffler 245-50-16 falken 502\'s descreened MAF 1pc driveshaft<br /><br /><br />soon to come: fixing that dagum Quarter Panel that i jacked up.<br /><br /><a href=\"http://www.geocities.com/heartland_heat_v6\" target=\"_blank\">Heartland Heat V6</a> &lt;----CO-FOUNDER<br /><br /><a href=\"http://www.dahleinsurance.com\" target=\"_blank\">NEED INSURANCE?</a>
        hmm ill have to look into both of these things, another thing i noticed it seemed to start a few week after i put on the bmr strut tower brace, wonder if that might have anything to do with it also.
          I used to have the same problem and it was my upper ball joints. They are pretty cheap, but not the easiest to fix. They definitely cleared up the popping problem though.
            2001 Black Z28 M6<br />Sprayed, slotted, geared and more~
