How long should it take me to install it? any tips?
Poly trans mount
This topic is closed.
It takes me about 10 minutes from the first pump of the jack to lowering the car down. But I've done it about 15 times or so now.
I'd say a half hour at the most, if you take your time.
About the only tip I can think of is to not try and align the bolt hole by threading the center bolt. Instead, jack the tranny up and wait till its flush with the crossmember - then put that center bolt in.
Its really straight forward once you get down there.
5 bolts on the crossmember - 2 on each side. 1 center bolt.
And the transmission mount is held in place by two bolts.
I think you need a 14 and 15mm sockets with a 6" extension.<b>15.41</b> @ 89.80 & 15.45 @ <b>91.64</b>, 2.21 60ft, 3,440 raceweight, using <b>OEM</b> Equipment. <br />\'98 L67/M49 w/ 134,000 miles before spun bearing. \"<i>It\'s all stock, Baby</i>!\"
by ssms5411Not much going on, replaced my Kenwood double din stereo with a Pioneer double din, the Kenwood had problems. Then replaced my power inverter for my reverse...4 weeks ago
