my #(*&(#%)&*( rear has been makin noise for like 6 months now, and i could never find out what it is. but, a buddy with a Z28 brought this up today.....
my spring seats up top are fine, they are intact and in fairly good shape.
question is:
Is there supposed to be rubber between the spring and the little cup where it sits on the axle?
If you checked the spring bushing and it's fine I bet it's the shock bushing Ian. These are the rubber pieces that go under and above the mount (under the carpet behind each corner of the rear seat back)
I finally replaced my springs/shocks tonight and when I pulled the stock shocks out of the rear the bushings were nearly falling apart. My spring bushings look great though.
Yeah, looks almost like an endlink bushing, a solid doughnut-shaped rubber bushing. One goes under the car (on top of the shock) and one goes in the car (on top of the mounting hole).
To check the top bushing you can just pull back the carpet from the side immediately behind the rear seatback. There will be a white foam padding over top of the shock mount. Pull that out and you'll see the top of the shock sticking up through the body. There's a nut, a washer and the bushing on there.
To check the lower half of the top bushing you'll have to remove those top pieces, unbolt the shock from the rearend and it should fall out.
o nut
- washer
O bushing
----- car body
O bushing
- washer
| shock body
L attachment to rearend
i doubt thats your problem. that would be inside the car.. have you made sure your tailights are tight. mine rattle sometime and all it takes is a little tightening and its back to normal.
The thudding sound is usually something loose.... Have you changed shocks? If the lower nut on the shock is not torqued enough it'll make a thud sound. Supposily the LCAs make a thud sound if too loose and a squeak when too tight.
"I ain't too big to listen to the rumors, I'm just too @#$% big to pay attention to them" - Dr. Dre http://seppo.hopto.org/
