ok, i don't know the exact name for this part but I totally bent it and my steering jacked. It's the threaded bar that extends from the steering rack(?) and connects to the tie-rod end. That steel bar is bent. I now have to get two new front tires plus that part -- oh and I got a speeding ticket. It's going to be an expensive month. How much am I looking at too?
~02 W68 Crow-Black Bird~<p><a href=\"http://www.cardomain.com/id/dravensbird02\" target=\"_blank\">scratch n sniff</a>
<blockquote>quote:</font><hr>Originally posted by AllTheGoodNamesAreGone: It all depends on where you get the part.. it shuld not be that bad.. probably less then the tires..
not that hard to fix either..<hr></blockquote>
any suggestions on how to fix?
<blockquote>quote:</font><hr>Originally posted by Dojo2000:
Check your Haynes manual (you do have a Haynes manual, don't you [img]tongue.gif[/img] )
I'll look it up in mine later, but I have to go to work now.<hr></blockquote>
yeah I looked at my haynes book. It only explained how to remove the tie-rod END --- not the rod itself. Although, my haynes book is for the 93-97 (from when I had my 93 bird). Anyone else w/suggestions?
Haven’t done anything on the Camaro, but put LEDs on my truck headlights . And my oil pressure sensor went out on the truck so going to fix that this...
