stock vs. poly bushings - FirebirdV6.com/CamaroV6.com Message Board
  • stock vs. poly bushings
    i am thinking on replacing my worn out stock rear sway bar bushings. Does energy susp. make a replacemtn for the endlinks or do just the little bushings they sell fit? or will the stock performe the same? thanks for the help.
    Mods List:FREE ram air mod,FREE air lid smoothing mod,Air silencer removal,K&N Filter,Magna Flow Exhaust. cat delete, 3.42 + lsd.2600 stall tc,alto red eagle complete tranny rebuild.
    Advance has poly swaybar endlinks for $6.13 each.
    Part# 18203HD (the heavy duty, standard is just rubber)
    I put all 4 on when I redid my suspension recently.
      ok thanks i looked at those online earlier. Did you notice a difference at all fom the stock ones?
        I put on SLP Eibachs and KYB AGX at the same time so I can't tell you if the endlinks alone would make a difference.
          alright thanks
            Poly endlinks are helpful, I run them. [img]smile.gif[/img]
            2002 5-spd NBM Camaro
            Details: www.1lev6.com
