i am thinking on replacing my worn out stock rear sway bar bushings. Does energy susp. make a replacemtn for the endlinks or do just the little bushings they sell fit? or will the stock performe the same? thanks for the help.
stock vs. poly bushings
Advance has poly swaybar endlinks for $6.13 each.
Part# 18203HD (the heavy duty, standard is just rubber)
I put all 4 on when I redid my suspension recently.1994 Firebird 3.4<br />15.65 @ 86.8<br /><a href=\"http://www.funkz.net/firebird.htm\" target=\"_blank\">funkz.net/firebird</a><br /><a href=\"http://mywebpages.comcast.net/funkz/timeslips.htm\" target=\"_blank\">Timeslips</a>
I put on SLP Eibachs and KYB AGX at the same time so I can't tell you if the endlinks alone would make a difference.1994 Firebird 3.4<br />15.65 @ 86.8<br /><a href=\"http://www.funkz.net/firebird.htm\" target=\"_blank\">funkz.net/firebird</a><br /><a href=\"http://mywebpages.comcast.net/funkz/timeslips.htm\" target=\"_blank\">Timeslips</a>
Poly endlinks are helpful, I run them. [img]smile.gif[/img]2002 5-spd NBM Camaro
Details: www.1lev6.com
