Questions for all the kits to compare:
1. Can you only run pads from only the manufacture of the brake kit? Meaning I can't buy pads anywhere else.
2. How much extra brake dust did you get?
3. How much extra stopping power did you get at the track/street/etc?
4. How was the installation of the kit? Example, dificult and had to cut parts of the spindles vs. Easy to install and re-used stock spindles, or bolted on new xxx parts.
The brake kits I would like to compare are the wilwood 6 piston brake kit, the new Stainless Steel brake corp. 3 piston set up, and the Baer 2 piston GT+ set up.
Additionally, I saw in summit and jegs where they had oversized GM calipers with a 2 3/4" piston that is supposed to give like 20% more stoping power... Is this only true for the older cars? I thought 98+ had 2 3/4" pistons?
If this is not true has anyone used this simple upgrade. If yes, how did you like it?
Thanks guys and gals,
JAM
[img]smile.gif[/img]
JAM
