rotors!! - FirebirdV6.com/CamaroV6.com Message Board
rotors!!
  • rotors!!
    its that time, rotors feel like crap, not sure what to do.
    1st option. get them turned. how much??
    if i take this option, would a dremel polish off the rust all over the non "skid" areas?
    2nd option. buy new rotors, i know theres cryo treated, slotted, crossdrilled, just looking to get a nice set of rotors that will do the job and look very nice for a long time without spending all my other mod money. suggestions?
    thanks
    - \"So you have something to look at when you\'re talking to \'em\" - <br /> <a href=\"http://www.cardomain.com/member_pages/view_page.pl?page_id=296916\" target=\"_blank\">http://www.cardomain.com/member_pages/view_page.pl?page_id=296916</a>
    It should cost between 5-10 dollars a rotor to have them turned.
    <a href=\"http://www.fatninjas.com/camaro\" target=\"_blank\">\'96 Camaro Convertible</a>
      Well I just ordered my slotted and cross drilled rotors from a company called iRotors. www.irotors.com. Will post pics up for you when I get them. It should run you under $240 for all four rotors.
      <b>98 Pontiac Firebird</b><br /><b>Mods:</b><br /><b>Exterior:</b> 19\" Konig Appeals Diamond Cut, Wings West Body Kit shaved and molded, shaved door handles, shaved gas tank, shaved rear spoiler, shaved license plate area, molded front and rear bumpers, shaved front and rear reflectors, removed PONTIAC from rear, shaved third break light, molded front firebird plate, custom yellow paint, relocated gas to trunk, 50lb door poppers, yellow udercar neons<br /><b>Suspension:</b> Custom fast bag setup, 4 valves w/ 3/8 line, V8 rear axle from a V6 one.<br /><b>Engine:</b> Motor swap to a LT1 Vette, computer prgrammed, custom dual exhaust. (Motor was swapped from a V6... Couldn\'t afford the LS1 so got the LT1)<br /><b>System:</b> 2 12\" Eclipse Titaniam DVC Subs, 1200Watt MMats Amp, 0 Gauge Wire<br /><b>Interior: </b> Full Yellow and Black Interior. All smooth with fiberglassed. Yellow and black seats wrapped. Black Carpet. Tribal Graphics. <a href=\"http://www.virtualpalmbeach.com/pcfirebird/pcbird8.jpg\" target=\"_blank\">http://www.virtualpalmbeach.com/pcfirebird/pcbird8.jpg</a>
        im not sure if i need to change mine they ar OE rotors that have original 43000 miles what should i do.
        oh yea the car shakes like $hit at 75mph and up. always has even after balancing the wheels like 30 times
        but i doesnt give much if any vibration under braking
        •)))2000 3.8L V6 FIREBIRD (Navy Blue) 5 speed <br />•Aluminum Alloy 3-piece custom built wheels - 17x10 (front)- 17x11.5 (rear) Tires:Front: 275/40-17 - Rear:315/35-17• Suspension Techniques 1 3/8 \" Solid front Sway Bar• H&R Springs • Koni revalved double adjustable shocks (front)• Bilstien Custom Revalved shocks (rear)• K&N •Magna Flow Dual Exaust• Stock wheels W/Hoosier Road Racing tires • Sound System•<br /><a href=\"http://www.cardomain.com/id/o0oskamo0o\" target=\"_blank\">•THE RIDE•</a>
          <blockquote>quote:</font><hr>Originally posted by PC Firebird:
          Well I just ordered my slotted and cross drilled rotors from a company called iRotors. www.irotors.com. Will post pics up for you when I get them. It should run you under $240 for all four rotors.<hr></blockquote>
          they're prices are cool... but where's the pics the the rotors?
            Autozone, $40 each or so. Drill them yourself if you like, it doesn't do a damn thing. Don't bother debating this fact, we've all rehashed it a million times.
            -Rob
              SKAM - had the same problem many times. Only people I know that have been able to balance tires right for me is Sears :( Give them a shot, satisfaction or your money back you know.
              2002 5-spd NBM Camaro
              Details: www.1lev6.com
                I too have the same problem with top end unstability. But you can get rotors for as little as $20 a piece. I tried that route once and one of them was warped out of the box, so I guess you get what you pay for.
                1995 Firebird 3.8 A4, 140,000 miles and going strong<br />Basically Stock, college=poor <p>Junior Mechanical Engineering Student: Milwaukee School of Engineering; Cpl, MN Army National Guard...just got promoted :)
                  If you are getting vibrations when you get to certian speeds, and balancing your tires isn't helping, I know what the problem COULD be. There are two potential problems: Warped tire (not out of ballance) has a deformed place, like a warble (blob sticking out somewhere) on either side of the tire; the other reason, bad treaded tire(s) have treads that don't run in a linear symetric path (where your tread should run strait but instead curves in one spot). Those can cause vibrations, and COULD be the cause.
                  ~Chris<br />1999 Hugger Orange Camaro<br /> <a href=\"http://www.cardomain.com/ride/273836\" target=\"_blank\">http://www.cardomain.com/ride/273836</a> <br /><br />†…faith…hope
                    <blockquote>quote:</font><hr>Originally posted by Dominic:
                    SKAM - had the same problem many times. Only people I know that have been able to balance tires right for me is Sears :( Give them a shot, satisfaction or your money back you know.<hr></blockquote>
                    Too bad you don't live in AZ, I bet you $1000 I can balance a tire better than anyone at sears. We fix their problems all the time. It all depends if you get the right guy at the right time.
                    1997 Dodge Viper GTS
                      Off topic, slightly...
                      How long do rotors last for? Also, how long to drums last for before needing service?
                      --<b>David</b>--<br /><a href=\"http://bryant2.bryant.edu/~dsantore/index.htm\" target=\"_blank\">The <b>NEW</b> V6Bird Website!</a> <br /><a href=\"http://members.cardomain.com/thev6bird\" target=\"_blank\">Cardomain site</a><br />ΔX
                        Disc rotors last between 40,000-100,000 miles, you just have to check their thickness when you do pads. Turning rotors shaves a lot of life off them.
                        Drums can wear thin too, but typically don't - you're probably fine for a very long time with them.
                          Are the ones at Autozone for $40/each any good? I mean, do you get what u pay for? I just want the stock ones replaced cuz my car vibrates when i brake at speeds over 85...
                          2001 Camaro A4<br />Maroon Metallic <br />Y87,Monsoon 500w,TTops<br />Appearance: Silver ZR1s w/ 275\'s<br />Intake: !Air Silencer, FRA Mod, k&n<br />Exhaust: 3\'\' Cat, 3\'\' B&B TriFlo<br />Misc: SLP Fan Switch, 1LE Boxed LCAs <br /> <a href=\"http://www.cardomain.com/id/mshapiro\" target=\"_blank\">http://www.cardomain.com/id/mshapiro</a>
                            i had my rotors turned at 12000 miles, new ones at 26000 as well as new pads. I hate the stock front rotors and pads. when I get the cash, I'm upgrading to a wilwood 6 piston kit. why keep buying rotors and pads if ur gonna wear them out every 26000 miles? yes, it was free for me since the car was under warranty, but still, it shouldn't have had to be done.
