Hi everyone, I am new to the group, you people really seem to know a lot about a lot . I was reading in the modification encyclopaedia about subframe connectors. It stated that convertibles have factory connectors in them. My question is, are they good enough and how much power can I put in it without folding it in two. I plan to use the car as a daily driver but want more power and cornering ability. Hopefully I can do a lot with this car it is stock at the time and only has 20K on it so it is a clean slate to work with. Thanks for any advice.
Subframe connectors
BMR makes a convertible subframe connector and should add more rigidity to your car, as I don't know alot about the factory subframe connectors I can't be 100% sure but I would say with a reasonable amount of certainty that if you really want to put power down they are going to help you over the stock setup.
http://www.bmrfabrication.com-Brad
2000 V-Star Custom 1100
:rock:
converibles have a double floor board, they do not have a real subframe connector, the way mustang verts do.
any added on one is good ;)
Ryan.1998 Ws6 Ta M6 #370 Bright Red<br />Custom \"NX\" style switch panels $35<br />Plug in fan switches $50 <br />SLP lid, Pro 5.0, Corsa, Custom Fan switch<br />....vortech waiting to be installed.
Originally posted by Hats Off:
Thanks for the info on the subframe. Black98v6 or anyone know anything about the reputaion of BMR's products. Good/bad- Josh<br />If you have any questions or need installation pics/help, e-mail me: Viper98885@aol.com<br /><a href=\"http://Camaroz28.cardomain.com/id/viper98885\" target=\"_blank\">\'93 Camaro Hardtop</a><br /><a href=\"http://Camaroz28.cardomain.com/id/01lincolnls8\" target=\"_blank\">\'01 Lincoln LS8 Sport</a><br />\'00 Yamaha YZF-R6<br /><a href=\"http://www.ftpp.net\" target=\"_blank\">Full Throttle Performance</a>
I have BMR subframe connectors on my WS6 and I like them a lot. Definitely helped to stiffen the chassis.
Chris<b>2002 BSM TransAm WS.6 M6</b><br /><b>350rwhp, 365rwtq</b><br /><b>Stock:</b>13.455 @ 105.39 2.129 60\'<br /><b>Mod:</b>12.449 @ 113 1.832 60\'<br /><br /><b>2004 QSM GTO M6</b><br /><b>303rwhp, 329rwtq</b><br />Stock: 13.74 @ 102.14 2.1 60\'<br /><br /> <a href=\"http://members.cardomain.com/silvertaws6\" target=\"_blank\">http://members.cardomain.com/silvertaws6</a> <br /><br /><b>1984 Firebird S/E M5</b><br />2.8L
if you don't mind welding, the bmr are great [img]smile.gif[/img]
Ryan1998 Ws6 Ta M6 #370 Bright Red<br />Custom \"NX\" style switch panels $35<br />Plug in fan switches $50 <br />SLP lid, Pro 5.0, Corsa, Custom Fan switch<br />....vortech waiting to be installed.
Converts have some additional chassis bracing, but it's nowhere near enough. They still are the most flexible f-body chassis and can use sfcs more than any other.
A quality install job is at least as important as which particular sfc you get.2000 Firebird convert, chameleon/tan, M5, Y87, TCS, BMR tower brace and panhard, KBDD sfcs, 245/50-16 GSCs
