any body out there with 17 inch rims and have a 245/35/17 series tire on their rims, or any 35 series tire?? If so, when going around corners really fast, does your rim actually touch the ground at all??
really low prof. tires..hurt my rims??
99 Firebird Vert, Pewter Metalic<br />Fast Toys Ram Air<br />Jet Stage 2 Chip<br />17x8 Mille Miglia Emotion II Plus\'<br />wrapped in 245/35/17 Yokohama A520<br />Rhino Perf. Exhaust<br />K&N air filter<br />check pics at:<br /><a href=\"http://www.fastrides.com/members/v6birdy/\" target=\"_blank\">http://www.fastrides.com/members/v6birdy/</a>Tags: None
the sidewall height is determinant on the tire width. a 275-40 tire will have 11 cm. of sidewall, a 235-55 tire will have 12.925 cm. of sidewall, and a 275-35 tire will have 9.625 cm. of sidewall. to find out sidewall, take tire width, and multiply it by the sidewall #/100. so, your 275-35 sidewall formula will look like this: 275(mm.)x (35 mm./ 100 mm.)=96.25 mm.=9.625 cm. I suggest not hitting too many potholes or sppedbumps too fast, unless you want the rims bent. less sidewall=better lateral grip, better appearance, less ride quality, possible lowered stance of car(depending on rim size).2001 Arctic White Firebird<br />T-Tops, 3.42 rear gear stock<br />Mods:K&N Air Filter,Whisper Air Induction Lid, maf screen removed, raised air box, Kumho Ecsta 712 255-50-ZR16 tires, BMR stb<br />Mods not installed yet: FTRA, SLP Lsd/Differential cover<br />Near Future Mods: HPP3, GMMG 3\" Exhaust , 1LE Swaybars, Transgo Shift Kit, MSD-DIS-4 w/ Accel Coil-Packs, Turquoise Blue Neon Underbody Kit, BMR Adj. LCA\'s, G2 Sfc\'s & V-braces, Pacesetter headers
that is one hell of a sidewall man, 11cm, that kinda tire wouldnt even fit in the wheel well, you mean the width of the tire would be 11 cm!!
DID you read my question? what you said has nothing really to do with my question. ;)99 Firebird Vert, Pewter Metalic<br />Fast Toys Ram Air<br />Jet Stage 2 Chip<br />17x8 Mille Miglia Emotion II Plus\'<br />wrapped in 245/35/17 Yokohama A520<br />Rhino Perf. Exhaust<br />K&N air filter<br />check pics at:<br /><a href=\"http://www.fastrides.com/members/v6birdy/\" target=\"_blank\">http://www.fastrides.com/members/v6birdy/</a>
<blockquote>quote:</font><hr>Originally posted by 99firebirdconv.:
DID you read my question? what you said has nothing really to do with my question. ;) <hr></blockquote>
umm... CM (centimeters) are small... i think u are thinking of INCHES<b>*§*Julian*§*</b><br />*~*~*~<br />2000 Grand Prix GTP -Daytona 500 Edition (only 2000 made) - Supercharged 3.8L V6<br /><br />1998 3.8L V6 A4 Firebird w/ W68 package, Y87, T-TOPS!<br /><br /><a href=\"http://myweb.usf.edu/~jadidona/index.html\" target=\"_blank\">MY SITE - CHECK IT!</a>
SIDEWALL = Space between the top of the wheel, to the tread...hence the name SIDE WALL. I think there are some confused people on this thread. its pretty funny that the self explanatory (sidewall) could get confused with tire width.1993 3.4 <br />Borla rear section<br />3 inch Catco High Flow Cat<br />2.75 inch I pipe (Picked one up from an LT-1 guy for a whole $10)<br />K&N Fipk <br />180° T-stat<br />Jet Stage II<br />10 Spoke Z28 Wheels<br />NGK\'s, Taylor Spiros<br />Mobil 1 synthetic<p>Email Viper2@chesnet.net for 4th gen replacement parts.
11 cm = 4.3 inches
to find inches devide CM by 2.54
If your rims are touching the ground in corners, there's a huge safety issue. I would even venture to say that you would get tire/rim separation before that would happen.
At any rate, my buddy had a blazer with some rediculous PIMPIN' wheels... 20's or something. The tire looked like a rubberband with tread. Besides the bone-jarring ride, there weren't any rim grinding problems.
Hope it helped.
-BrianMaroon 1995 Camaro<br />No mods yet...<br />Lucky to have found this site!
yeah i know what the sidewall is, i think it was Patrick that was kinda screwed up with the sidewall, cuz there is no way a 275/40 will have an 11cm sidewall.....see what im saying?? :D99 Firebird Vert, Pewter Metalic<br />Fast Toys Ram Air<br />Jet Stage 2 Chip<br />17x8 Mille Miglia Emotion II Plus\'<br />wrapped in 245/35/17 Yokohama A520<br />Rhino Perf. Exhaust<br />K&N air filter<br />check pics at:<br /><a href=\"http://www.fastrides.com/members/v6birdy/\" target=\"_blank\">http://www.fastrides.com/members/v6birdy/</a>
Patrick is dead right on this one.
275/40 means this:
275mm wide = 27.5 cm wide (about 11 inches)
27.5 cm wide X 40% = 11 cm tire height = "sidewall" (about 4-1/4 inches)
And there is no way you'd get the rim on the ground if you had air in the tire.
[ May 14, 2002: Message edited by: V6Bob ]</p>2000 Firebird convert, chameleon/tan, M5, Y87, TCS, BMR tower brace and panhard, KBDD sfcs, 245/50-16 GSCs
Sorry Patrick and bob but i was just at Kal tire to pick up my car cuz i got new rims and tires, and i looked at a 275/40 on a rim, and from the top of the rim to the top of the tire.... guess what, it only has 2.6 inches of SIDEWALL. [img]tongue.gif[/img]99 Firebird Vert, Pewter Metalic<br />Fast Toys Ram Air<br />Jet Stage 2 Chip<br />17x8 Mille Miglia Emotion II Plus\'<br />wrapped in 245/35/17 Yokohama A520<br />Rhino Perf. Exhaust<br />K&N air filter<br />check pics at:<br /><a href=\"http://www.fastrides.com/members/v6birdy/\" target=\"_blank\">http://www.fastrides.com/members/v6birdy/</a>
you're forgetting that the sidewall sticks out a bit cuz of the air pressure in the tires. it'l look like 2 in., but if you were to take the tire off and deflate it, it'll be 4 in.2001 Arctic White Firebird<br />T-Tops, 3.42 rear gear stock<br />Mods:K&N Air Filter,Whisper Air Induction Lid, maf screen removed, raised air box, Kumho Ecsta 712 255-50-ZR16 tires, BMR stb<br />Mods not installed yet: FTRA, SLP Lsd/Differential cover<br />Near Future Mods: HPP3, GMMG 3\" Exhaust , 1LE Swaybars, Transgo Shift Kit, MSD-DIS-4 w/ Accel Coil-Packs, Turquoise Blue Neon Underbody Kit, BMR Adj. LCA\'s, G2 Sfc\'s & V-braces, Pacesetter headers
<blockquote>quote:</font><hr>Originally posted by V6Bob:
275/40 means this:
[ May 14, 2002: Message edited by: V6Bob ]<hr></blockquote>
That's right.
The shorter the sidewall the stiffer it is. It's just going to be uncomfortable if it's short.
From the Goodyear website:
Tire Size
Service Description
Sidewall
ApprovedRim Width
Meas. Rim Width
Section Width
O.D.
Tread Width
Max.Load
P275/40ZR18 94Y VSB 9.0- 11.0 9.5 10.9 26.6 10.3 1,477
So the outer diameter is 26.6 inches, the wheel is 18 inches. That leaves 8.6 inches for 2 sidewalls or 4.3 inches for each.
The wheel 99firebirdconv. measured must have one heck of a big lip covering up 1.7 inches of sidewall. Or he must not have measured to the top of the tire (maybe he measured just just to the rounded edge where the tread begins?).
Aha! Lightbulb! I'll bet that's it. We're arguing about whether the "sidewall" measurement goes to the top of the tire or just to where the edge of the tread begins. The first is how tire measurements are stated, the second has a certain "common sense" appeal.
Original 4th Gen V6 understood a long time ago but he confused me by saying "width", where "height" would have done the trick.
that 4.3 inches is without the rim on, there is a lip on the sidewall that kind of goes inside the rim, with that lip on the tire then it is 4.3 inches. :D99 Firebird Vert, Pewter Metalic<br />Fast Toys Ram Air<br />Jet Stage 2 Chip<br />17x8 Mille Miglia Emotion II Plus\'<br />wrapped in 245/35/17 Yokohama A520<br />Rhino Perf. Exhaust<br />K&N air filter<br />check pics at:<br /><a href=\"http://www.fastrides.com/members/v6birdy/\" target=\"_blank\">http://www.fastrides.com/members/v6birdy/</a>
