i might have a good deal going on some polished z06 18 inch wheels and tires,would these slow me down at all????? i have a 95 3.4 with an a4
would 18s slow me down
Yes they will, I noticed a difference between a 245s and 235s on the different sets of wheels.
Big difference between my 275s and 17s and my any tires on 16s...-Eric<br /><a href=\"http://www.cardomain.com/id/mustangeater82\" target=\"_blank\">2000 NBM V6 Camaro 5-speed</a> T-top <i>converted</i><br /><b>14.467@95.45mph</b> <i>$0 in mods</i><br /><i>The member formerly known as MustangEater8251</i>
Yes because the slight weight and size difference would slow down the wheels from spinning a lil but you can always change out the clutch, tranny, and/or flywheel and also add
MORE POWER!!!!!!!!!!!!!! [img]graemlins/rock.gif[/img] and take advantage of the longer push and increased tire surface area touching the ground-RJ \"Like trail mix I\'m a lil sweet but mostly nutty\"<br />Metallic Blue 2001 3.8 Firebird M5<br />FRA,Smoothed Air lid, Homedepot Intake, K&N Air Filter, MSD Coils & Plug wires, Iridium Plugs, Flash Tune, 2.5 Flowmaster Catback.
problem is most people are generally brok after buying 18"s [img]smile.gif[/img]-Eric<br /><a href=\"http://www.cardomain.com/id/mustangeater82\" target=\"_blank\">2000 NBM V6 Camaro 5-speed</a> T-top <i>converted</i><br /><b>14.467@95.45mph</b> <i>$0 in mods</i><br /><i>The member formerly known as MustangEater8251</i>
Originally posted by beeker82:
ok,would 17s be as bad??? right now i have the salad shooters with 245/50s i think,ill just go with 245/45/17s,would this be a huge difference?
also, this is headed to the suspension forum.
Unfortunately, that longer push requires more power to turn the wheel. Which is why they slow your car down. Secondly, the increased tire surface area is also cancelled since more power is required to turn the wheel. And of course, if you use low profile tires, both of those 'benefits' are cancelled off the bat.
:rolleyes:
Honestly, I haven't noticed a difference. I went from 245/50/16's to 265/35/18's. The height was nearly the same and the overall ride actually feels better. Tire-wise, I went from Michelin Pilot Sports to BFG GForce Kd's so maybe that has something to with it too. The BFG's are awesome. I love em'. As some of the others mentioned, you could lighten up your car in other ways to make up the difference too. I'm installing an aftermarket hood soon..2004 CE Corvette 10.86@132mph
2011 Cadillac CTS-V
2006 Mitsubishi Eclipse GS
Originally posted by Shirl:
Honestly, I haven't noticed a difference.I went from 245/50/16's to 265/35/18's. The height was nearly the same and the overall ride actually feels better. Tire-wise, I went from Michelin Pilot Sports to BFG GForce Kd's so maybe that has something to with it too. The BFG's are awesome. I love em'. As some of the others mentioned, you could lighten up your car in other ways to make up the difference too. I'm installing an aftermarket hood soon..
And yes, it will handle better. Increasing the size of the wheel (not tire) improves handling since there is less give.
Do you have any times to back that up?
Not to but heads here but weight reduction isn't the same as increasing/decreasing rotational mass.2004 CE Corvette 10.86@132mph
2011 Cadillac CTS-V
taller side wall is said to give better traction during launch..but i dunno..this is what i noticed running 3 times NA (i forget mph)..same burnout..same stall/launch..
18" C5s w/ BFG drag radials 15.67
16" Weld pro star XPs with M/T ET Streets 15.68
..basically..i didnt see any difference..could make a difference once i hit the juice though..not sure<b>12 SECOND DUAL STAGE DRY NITROUS POWERED 98 A4 V6 CAMARO<br /><a href=\"http://www.mysickcamaro.50megs.com\" target=\"_blank\">www.MySickCamaro.50megs.com</a><br />Best ET: 12.82@103<br />Best MPH: 104.7<br />Best 60\': 1.75 - Stock TC</b><br /> </font><blockquote><font size=\"1\" face=\"Verdana, Helvetica, sans-serif\">quote:</font><hr /><font size=\"2\" face=\"Verdana, Helvetica, sans-serif\">Originally posted by Shodown:<br /><strong>1DV6 runs 12\'s...enough said. </strong></font><hr /></blockquote><font size=\"2\" face=\"Verdana, Helvetica, sans-serif\">
