Do these springs lower/raise the car or is it the same height as the stock springs?
1LE Spring Height
1LE Spring Height
1996 Camaro 3.8L A4<br />*RK Sport Headers, RT High Flow Cat, B&B Tri-Flo Catback w/Quad Tips<br />*17\" Camaro SS Rims w/Firestone Firehawk SZ50 EP (275/40/17 Front, 285/40/17 Rear)<br />*SLP Speedometer Recalibrator<br />*American Sports Car SS Style Hood, Painted Green Disc Calipers and Drum Shells<br />*Charcoal Leather InteriorTags: None
Then is there any springs that keep the car at ride height, the reason i ask is because im getting new shocks. Would it be possible/smart to just upgrade the shocks (Bilstein HDs) and buy new OEM springs?1996 Camaro 3.8L A4<br />*RK Sport Headers, RT High Flow Cat, B&B Tri-Flo Catback w/Quad Tips<br />*17\" Camaro SS Rims w/Firestone Firehawk SZ50 EP (275/40/17 Front, 285/40/17 Rear)<br />*SLP Speedometer Recalibrator<br />*American Sports Car SS Style Hood, Painted Green Disc Calipers and Drum Shells<br />*Charcoal Leather Interior
<blockquote>quote:</font><hr>Originally posted by Brendan Hearn:
Then is there any springs that keep the car at ride height, the reason i ask is because im getting new shocks. Would it be possible/smart to just upgrade the shocks (Bilstein HDs) and buy new OEM springs?<hr></blockquote>
I don't follow. You can just get Bilsteins and keep your stock springs. Or you can get 1LE springs. Both will work. I don't see why you would want to buy the same springs are you have now.
Well if your considering puttin much of a stereo in your car and it's 97 older i'd suggest going with the Ile replacments i did and boy i'm glad i did i added you could say close to 100 lbs in the back and well the stock ones are just to weak for that kinda weight it looked like i had lowered my car and it road terrible i was consdinerg just doing the 114lb upgrade ones that the newer 98 have but i went with the 130-170 1le replacments i also decided to up the front springs to what the new 98 v6 have with the 256 or 257 i think over the 235 which is already stock on the car
Dom that could be what he was asking about keepin his height if he added more of a stereo later i don't know just givin my opinion<a href=\"http://www.sounddomain.com/id/boboboom2\" target=\"_blank\">White 96 RS t-tops Auto 3.08 gears</a><br />Check link for car and all mods<br />USACi Outlaw Spl and SQ competitor<br />Soon to come Batmans SC running 10 psi and PCM programing<br />99 Honda VFR Motorcyle 100.5hp@10,750RPM 1/4 11.14@122mph, 0-60 3.36sec, 0-100 7.92sec<br /><a href=\"http://www.sounddomain.com/id/boboboom\" target=\"_blank\">99 Dodge 2500 Cummins Quad cab 5 speed 325hp</a><br />Check link for all mods and pics
I just wanted new shocks and a lot of people had told me that you gotta go with new springs also, but all the ones that i found were lowering springs with the exception of the 1LE ones. I posted the topic b/c i wanted to keep my stock ride height and thought that i needed to go with new springs.1996 Camaro 3.8L A4<br />*RK Sport Headers, RT High Flow Cat, B&B Tri-Flo Catback w/Quad Tips<br />*17\" Camaro SS Rims w/Firestone Firehawk SZ50 EP (275/40/17 Front, 285/40/17 Rear)<br />*SLP Speedometer Recalibrator<br />*American Sports Car SS Style Hood, Painted Green Disc Calipers and Drum Shells<br />*Charcoal Leather Interior
I just installed 1LE springs on my car and the the height diff. is very minimal, say less than half an inch. I also changed out the shocks with Bilsteins at the same time. They give you a nice firm ride, with good handling. You can also get the shock modified to use coilovers and use the stock springs or get any spring rate you like then raise or lower the ride height at any time.FRANKLIN H. <br />1995 Silver Camaro L32 <br />K&N,Flowmaster,HPP,160*,1LE,Zexel-Torsen,ES,BFG,Michelin,Bilstein,Eibach,C5 rims,!CAT,!AC
I just wanted new shocks and a lot of people had told me that you gotta go with new springs also, but all the ones that i found were lowering springs with the exception of the 1LE ones. I posted the topic b/c i wanted to keep my stock ride height and thought that i needed to go with new springs.<hr></blockquote>
You don't need new springs with new shocks. If you like the springs you have then keep them. 1LE springs and Bilstein HDs work great. Stock springs with Bilstein HDs will also work good. When you get lowering springs then you need to buy the right shocks.
I'm debating on whether to get a coil-over setup, like in my sig, or just get BMR lowering springs w/ the matching HAL adjustable shocks. I'd say get lowering springs if you're gonna lighten your car, cuz it'll raise up w/ less weight in it. more weight, just get 1LE springs and matching shocks.2001 Arctic White Firebird<br />T-Tops, 3.42 rear gear stock<br />Mods:K&N Air Filter,Whisper Air Induction Lid, maf screen removed, raised air box, Kumho Ecsta 712 255-50-ZR16 tires, BMR stb<br />Mods not installed yet: FTRA, SLP Lsd/Differential cover<br />Near Future Mods: HPP3, GMMG 3\" Exhaust , 1LE Swaybars, Transgo Shift Kit, MSD-DIS-4 w/ Accel Coil-Packs, Turquoise Blue Neon Underbody Kit, BMR Adj. LCA\'s, G2 Sfc\'s & V-braces, Pacesetter headers
by ssms5411About a week ago noticed my brake lights not working also Hazards not working. Installed new brake switch and still not working, checked fuses and what...3 days ago
