Where and How much can i get a LSD? - FirebirdV6.com/CamaroV6.com Message Board
This topic is closed.
  • Where and How much can i get a LSD?
    I really want a LSD but I dont know where to get one. How much do they usually cost . . . . . im on a tight budget.
    Thanks
    Kyle
    99 Pontiac Firebird<br /><br /><a href=\"http://www.cardomain.com/memberpage/430960\" target=\"_blank\">http://www.cardomain.com/memberpage/430960</a>
    tight budget = www.slponline.com
    they have teh take out posi units that came stock in 4th gen V8 cars for $99.
    hope this helps
    later
    tim
    NJ SPEEDER<br />1976 Camaro LT<br />Crate 350, TH350, 3.90 posi<br />New Jersey F-Body Owners Association<br /><a href=\"http://www.NJFBOA.org\" target=\"_blank\">www.NJFBOA.org</a>
      1. DO A SEARCH!!! This topic comes up all the time...
      2. This is the wrong forum. This belongs in Drivetrain.
      3. Check the Modifications Encyclopedia - all the info you need for limited slip info is there. You can buy the Zexel-Torsen T2 as a take-off from Thunder or TByrne for $95. The advantage of buying from Thunder is you can also pick up 2 quarts of Redline 75W90 fully synthetic gear oil and 1 bottle of GM limited slip additive all in one shot and have everything you need.
