Going over speed bumps, I hear squeaking coming from the rear. Is this just one of those infamous mysterious squeaks that "the F-Body is notorious for?"
Squeaking in Rear
after I installed my bilstens and all the lLE stuff I had a sqeak and a clunk. Finally I got tired of my car making all this racket so I basically greased everything that moved back there. spring seats, sway bushings, shock mounts, control arm ends the only think I didn't do was the panhard bar. don't know why guess I just never worried about it. anyway I have a nice quiet car now :D-Brad
2000 V-Star Custom 1100
:rock:
can u get that lithium grease from a normal hardware store or something?
i was thinking about ummm urathane bushings but if that works ill try it-imagine if u will me driving over bumps trying to be cool :rolleyes: [img]graemlins/slap.gif[/img] then squeeeeeeeeeek-RJ \"Like trail mix I\'m a lil sweet but mostly nutty\"<br />Metallic Blue 2001 3.8 Firebird M5<br />FRA,Smoothed Air lid, Homedepot Intake, K&N Air Filter, MSD Coils & Plug wires, Iridium Plugs, Flash Tune, 2.5 Flowmaster Catback.
Lowes, Home Depot. Auto stores, etc all should carry the lithium grease in a spraycan. Or, go with the urethane bushings. Just be sure to grease the inside of the bushings where they contact the metal to prevent squeaks later on.sigpic
You might want to check if your spare tire is loose. Mine was and it would squeak over bumps, so I just tightened it and it went away.
