I have a stock rear suspension, 16" aluminum rims. Nothing fancy for tires, and they are getting close to being replaced (kinda bald) I get a nasty whell hop on the mo-fo. I figured poly bushings would help, they did on my 83 z28. But I see they make a weld on bracket to lower the control arms (mainly to fit with lowering springs) Mine isnt lowered. Basically I want to eliminate the wheel hop without getting too much money into the rearend. Thanks
Wheel Hop
The poly will help, might as well get some boxed LCAs as well. The relo brackets will benefit you as well even though you are lowered.2002 Pewter V6 Camaro M5 <br /><br />Quickest stock-motor N/A V6 4th Gen F-body.<br />2nd Quickest N/A V6 4th Gen F-body overall.<br />mods: Gear, weight reduction, tuning <br /><br />Fear the Gear. 13.585 @ 100.05 1.827 60\'<br /><br /><br /><a href=\"http://www.NJFBOA.org\" target=\"_blank\">www.NJFBOA.org</a>
