Lowering spring question - FirebirdV6.com/CamaroV6.com Message Board
  • Lowering spring question
    Can someone tell me if Apex lowering springs for 93 and up Camaro will work on either a V6 or V8.
    I have access to a set new that was bought for a V8, and are not going to be used. I'm wondering if they will be ok on a V6 application. Obviously the weight is different, and i know the car may not sit as low, but will they fit. Could i possibly have a machine shop grind a half inch off them maybe, too account for the height difference. Any help would be appreciated. thanx.
    I wouldn't cut em. The only way to tell if they'll look right is to install em. Every spring manufacturer has different spring rates. I have sprint springs on my ride which will work for the V8 fbodies as well.
    <b>99 Camaro Z28 A4</b><br />R.I.P. 00 Firebird 3.8<br />14.89 @ 90, 2.03 60\'
      They will fit and will work alright if you just want inexpensive lowering springs. If you're thinking about cutting on any springs, I won't go further than saying just that. ;)
      2002 5-spd NBM Camaro
      Details: www.1lev6.com
        cut em .. no torch ,portaband [img]graemlins/thumbsup.gif[/img]
          Thanx guys, i think i'll put in the rears first and see how it sits, if they need to go down a bit more, I can't see cutting a half inch or so out of them really effecting the ride quality that much. Thanx for the imput.
            Good luck
